Sponsored by: Auxito
Power steering question
Old Jun 24, 2011 | 12:04 PM
f15097's Avatar
f15097
I replaced my pump on my 1997 4.6 4WD truck and have had a lag or temporary loss in low RPM situations. It is not a total loss but temporary. I have come to realize that I put the wrong type of power steering fluid in the system. I do not have a squeal or any noise from the pump. What are the chances of removing the fluid and replacing it with the correct fluid that I do not need to replace the pump? Thanks
Old Jun 24, 2011 | 11:45 PM
KhanTyranitar's Avatar
KhanTyranitar
PS pumps don't like the wrong fluid, chances are by the time it starts cutting out that it is too late, but you can try changing out the fluid. The correct fluid is probably Mercon ATF, which has been superceeded by Mercon V.
Gcapell
Jul 17, 2012 06:25 PM
knecoli22
Mar 16, 2011 05:43 PM
suzanne9273
May 1, 2009 09:34 AM
paulford
Aug 9, 2006 01:01 AM
mcalvin85
Jan 17, 2005 07:30 PM
