Modular V10 (6.8l)
Vacuum leaks?
Old Jun 24, 2011 | 07:35 AM
Hypoid's Avatar
Hypoid
Vacuum leaks?
I'm having some trouble with my work truck. I can't just take things apart for a look-see, or run over to auto parts for a free scan.
The truck is a 2004 F-250 with the 6.8l V-10, 85,000 miles.
Are these engines known to have intake sealing issues?
Are there common areas for vacuum fittings or hoses to fail?
I don't want to get into the problem, or diagnostics. If I can't prove my theory, the truck gets parked, and I'm stuck in a dinky little Dodge until they can put it in the shop.
TIA, Mike
My ol' pal:
Old Jun 24, 2011 | 06:42 PM
samsdad02's Avatar
samsdad02
Check the pcv hose.
Old Jun 24, 2011 | 08:39 PM
BareBones's Avatar
BareBones
If I recall correctly, Harbor Freight has a mechanics stethoscope for about $3 that you could use to pinpoint a leak.
Old Jun 24, 2011 | 11:10 PM
Hypoid's Avatar
Hypoid
I can hear a hissing on the passenger side, toward the back. It's not so easy to go poking around in there. I'll give the PCV special attention.
Thanks again!
Old Jun 25, 2011 | 07:02 AM
Bbasso's Avatar
Bbasso
try the old trick, spray some wd40 in the suspect area and see if that changes the sound or idle of the motor.
If it works, you have confirmed the vacuum leak.
Old Jun 25, 2011 | 08:02 AM
projectSHO89's Avatar
projectSHO89
That "old trick" only works on "old" carburetor systems. The computer is too fast on modern fuel injected to ever tell the difference.
The basic mechanic's stethoscope has a solid probe for physical connection to the engine so it can pick up mechanical vibrations. It will not be useful for detecting a vacuum leak unless you can modify it with a hose or tube.
Old Jun 25, 2011 | 10:02 PM
powerstroke F350's Avatar
powerstroke F350
try ether or starting fluid it works on these trucks
Old Jun 26, 2011 | 03:57 AM
BareBones's Avatar
BareBones
Ha. You make a good point about the stethoscope.
Old Jun 26, 2011 | 08:36 AM
projectSHO89
Nope, the computer is still too fast. All you can do is connect a scan tool and watch the STFTs while spraying. Those will tell you when you've hit the right spot.
Old Jun 26, 2011 | 11:31 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I've been able to detect intake manifold leaks on modern fuel injected engines by spraying a combustible fluid around the intake.
Old Jun 27, 2011 | 08:45 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Hypoid, check that infamous PVC plumbing elbow, right where it attaches to the throttle body. It's known to rot and/or crack. I'm lucky, mine is still good (knock on wood).
Other than that, no, the V10 and the modulars are not "known" for intake vacuum leaks.
What's the trouble? If it's running lean overall, clean the MAF and change the fuel filter.
Old Jun 30, 2011 | 08:30 PM
Hypoid's Avatar
Hypoid
Thanks Art! I'll be sure to give that fitting another look.
After talking to Shawns Fords, I'm leaning toward a fuel problem.
When I told Shawn the truck would die when it gets hot out, he thought the fuel pump might be starting to fail. The pump is only a year or two old, but one of our other V-10 trucks is having trouble as well. So far, it has gone though one fuel pump and three filters. Methinks one of the company's fuel trucks is delivering a load of trash when we fuel up.
The whole time this truck is acting up, the gauges read normal, no lights come on. I shut off to give it a cool-down, or park it overnight, no problem until the weather gets hot. I had a brand X with an aluminum top end act much the same way, except they were known to have gasket problems.
Time to requisition a fuel filter, and another can of sea-foam.
Hypoid
Colorado Chapter
43
Dec 3, 2023 07:54 PM
BigBlocker0248
Feb 20, 2016 09:35 PM
DumbLuck
Jan 28, 2015 04:09 AM
fordtruckman
Oil & Lubrication
Jun 2, 2010 01:00 PM
Dave85zxt
Aug 24, 2004 11:35 PM
