A couple PID questions
Old Jun 24, 2011 | 01:43 AM
exiled's Avatar
exiled
Is keeping up with the injector pulse width helpful at all?
Does anybody monitor the engine load? I've been watching it to try to get a grasp the load that sends the EGT to the limit. What I've seen is that the low engine loads raise the EGT temps and higher loads lower the EGT temps. Is this just something that I've caught at the right time? I would have thought higher the load the higher the EGTs.
Old Jun 24, 2011 | 06:54 PM
cheezit's Avatar
cheezit
load pid is just about useless. the onlything about pulse width that matters is thats its a number greater then 0
Old Jun 25, 2011 | 01:05 AM
exiled's Avatar
exiled
Thanks brother, yea I've noticed that engine load don't seem to mean much. Whatelse is worth monitoring?
Old Jun 25, 2011 | 05:35 AM
cheezit's Avatar
cheezit
while driving....
eot,ect,tft, vbatt maybe
Old Jun 25, 2011 | 02:13 PM
BLADE35's Avatar
BLADE35
from time to time I will also watch
ICP and IPR when you figure how to compare these two youl know when it leaks or have an issue
FICM
volts
VGT and boost
what do you monitor pids with SGII
Old Jun 25, 2011 | 03:27 PM
exiled's Avatar
exiled
Well I guess I have it covered then. I have my analoge isspro egt, tft, and turbo gauges and I have my insight showing ect/eot, alt and ficm. I still have 1 function to fill.
The insight ficm alert was factory set to 42 volts. A couple times starting the truck it has dropped to 42 just for a split second then rest if the time its betwen 45-47 vs. Is this normal?
Old Jun 25, 2011 | 04:11 PM
BLADE35's Avatar
BLADE35
[quote=exiled;10502227
The insight ficm alert was factory set to 42 volts. A couple times starting the truck it has dropped to 42 just for a split second then rest if the time its betwen 45-47 vs. Is this normal?[/quote]
your Ficm is just starting to fail slowly
Old Jun 25, 2011 | 04:31 PM
BLADE35's Avatar
BLADE35
were can I find what all the edge insight pids that can be monitored
never mind found it
Old Jun 25, 2011 | 10:18 PM
exiled's Avatar
exiled
So what am I watching for on the ficm. I might have been mistaking on the 45-47 v. Tonight it was staying above 46.7-47.?
Old Jun 25, 2011 | 11:06 PM
BLADE35's Avatar
BLADE35
look at the ficm voltage before start with koeo and watch it while idel should always be 48 or so volts
there is also
ficm lodgic power= 12 vlt
ficm vehicle power= 12 vlt
ficm main power= 48 vlt
Old Jun 26, 2011 | 12:29 PM
exiled's Avatar
exiled
What is a koeo and when you say 48v or so do mean 48+ or 47-48v?
Old Jun 26, 2011 | 01:06 PM
cheezit's Avatar
cheezit
koeo = key on engine off.
45v+
48+ is ideal
Old Jun 26, 2011 | 01:09 PM
BLADE35's Avatar
BLADE35
koeo= key on engine off
koer= key on engine running
47-49 volts for ficm ok should be 48 +/- a volt would be ok
according to the operating values Im looking at it needs to stay between 40-52 volts at all times or a cel will come on [service engine soon light]
Old Jun 26, 2011 | 08:11 PM
exiled's Avatar
exiled
Thanks guys. Its a pain in the butt to get my insight to come on koeo. I did it when I 1st hooked it up and set it up but since I think I only got it on 1ce. I hate having to leave the truck idel to change a setting or something. The only thing I'm not liking about the insight is not wanting to come on with key on, and its pretty slow for todays standards. Looking at a coupke seconds to move screen to screen.
Old Jun 26, 2011 | 08:24 PM
ljutic ss's Avatar
ljutic ss
I don't know what model insight you have , but my startup screen comes on about 6 seconds after key is turned on. Moving from screen to screen is instant.
