95 flasher problem
Old Jun 23, 2011 | 08:13 PM
motochris35's Avatar
motochris35
95 flasher problem
On my 95 f-350 my turn signals will begin to flash normally, then after 4 or 5 flashes it will start to flash real fast like one of the bulbs it out, but both front and back signals are flashing, this happens on both sides, and then will go back to normal, then back to fast, im baffled, thanx
Old Jun 23, 2011 | 08:22 PM
Action4478's Avatar
Action4478
Welcome ....
You may want to replace the flasher to start out ...
helifixer's Avatar
helifixer
swap your turn signal and hazard flashers and see if the problem stays or follows the flasher
Old Jun 23, 2011 | 08:26 PM
motochris35
thanx for the welcome, when u say replace the flasher, u mean the solenoid?
motochris35
helifixer, do u mean the bulbs??
Old Jun 23, 2011 | 09:04 PM
Action4478's Avatar
Action4478
Pull the cover to the fuse panel , you will see a round aluminum flasher . Replace it , & see what happens ...
The flasher for the 4 ways is on the back of the panel ...
Old Jun 23, 2011 | 09:11 PM
helifixer's Avatar
helifixer
no the flashers are mounted back to back on the fuse pannel. just swap them and see if the problem changes
Old Jun 24, 2011 | 07:10 AM
DIYMechanic's Avatar
DIYMechanic
The other thing you can try is to wiggle the Multi Function Switch (MFS or turn signal switch) when it starts this. Mine acts up intermittently and if I just wiggle the stick it settles down. I need to pull it out and spray it out real good with contact cleaner. It's just not at the top of my to do list right now.
Old Nov 13, 2013 | 09:50 PM
Gicknordon's Avatar
Gicknordon
I know this is an old thread but did this ever get resolved because having the same exact problem?
Old Nov 14, 2013 | 07:11 AM
mjunk1's Avatar
mjunk1
I don't know about being resolved but I had the same problem. It was fun for a while to see what "beat" the flashers were going to take when you turned on the signal. But, for $2.98 I got a new flasher and it fixed the problem. It is a very high probability it is the problem and a low investment.
BS51993
Jun 21, 2014 08:26 AM
Draft_Horse
1997 - 2003 F150
Dec 20, 2013 08:33 PM
whistle1516
Jan 31, 2012 09:07 PM
rfairwea
Dec 22, 2009 01:00 PM
M998
Electrical Systems/Wiring
Jan 29, 2007 09:33 PM
