idle surging
Old Jun 23, 2011 | 07:57 PM
jtipton331stroker's Avatar
jtipton331stroker
idle surging
hey guys i have a freshly rebuilt motor in my f150 work truck it is a 5.0 with long tubes straight pipes accel distributer lokar kickdown cable just some minor things after installing the motor and driving around for a for weeks sometimes outta the blue at stop signs it will just stall right out if ive been cruzing 60 then go to stop and then when its ideling everyknow and then it will bounce from 800rpms to 20 0rpms then back to 500 rpms. i changed the fuel filter plugs and wires, cleaned the throtle postion senor and replaced. some locals around the race track say to delete my egr. can i get some help here guys thanks
Old Jun 23, 2011 | 09:28 PM
Freightrain's Avatar
Freightrain
Sounds like a sticky IAC(idle air control) motor(little can bolted on by the throttle body). It's a simple air valve and it if sticks OPEN, it will lean the motor out and make it stall. Two small bolts removes it(don't tear the gasket), unplug it and spray some brake clean in it. It uses just a simple cone to seal and if it's gets gummed up it will either leak or stick.
My '89 needs it cleaned about every 5-6 months, cheaper then the $80 they want for a new one.
Old Jun 25, 2011 | 07:20 PM
jtipton331stroker
yea ive cleaned that thing a many of time now and i cant notice much difference. is ther any other ideals
Old Jun 26, 2011 | 05:34 AM
Freightrain
Have you cleaned out the EGR? Maybe it's sticking and causing the same issue as the IAC(lean the motor out).
Old Jun 26, 2011 | 09:24 AM
jtipton331stroker
im gunna try cleaning egr out today thanks for the help
cofferjl
Apr 9, 2013 02:26 PM
Mike Usher
Jul 31, 2012 04:45 PM
nothercrash
Apr 14, 2011 10:25 PM
XolieX
16
Jul 25, 2009 07:04 PM
muddingmcdude
Apr 30, 2007 08:52 PM
