Panel truck frame same as f100 shortbed?
They are the same, but, panel trucks have a small frame extension on the rear that is a bolt on extension.
http://i.ebayimg.com/images/g/0mMAAO...j~/s-l1600.jpg
Thanks guys! In the picture from the ad, it looks like a normal f100 frame? But he says its from a panel. I will take some measurements and look at the vin I suppose. It looks to be in pretty good shape.
http://nashville.craigslist.org/pts/5345546460.html
Received 4,118 Likes
on
Was hoping to get it for about $150. Unfortunately, I do need it - my frame has obviously been hit in the front at some point and it's tweaked. It's weird because all the sheet metal lines up and when I measure, it all comes out fine...so I have been sort of ignoring it and moving forward since all of my work has been bolt-on upgrades. But this frame is only about 45 mins away...so thinking I would be ahead by getting it and making the change now.
See in the pic where the frame is bent where the driver side brake hose enters the frame? Also, the front frame horns are all kinds of bent up.
You'll have to define "tweaked" a little bit more for me. If you've measured and cross measured and it is square, your sheet metal all fits fine, it sounds more like you've just got a couple bent flanges that will hammer out straight, and you're good to go. you may be worried about nothing. These frames are really easy to straighten. I wouldn't throw this one away for something as simple as what you've shown me so far.
Swapping frames involves swapping serial numbers, and you could be opening a bigger can of worms than you want to.
on
on
1953-56 Ford F-100 Frame Horn, Front Piece That Bumper Bolts To, Passenger
on
thomc
08-29-2018 06:28 PM
hoss73ford
08-30-2015 08:02 PM
uglytruck59
06-24-2011 07:56 PM
firstrider
03-18-2008 10:25 AM
