How much hp???
Old Mar 27, 2003 | 05:05 PM
Jsbiohazard's Avatar
Jsbiohazard
How much hp???
Hey ratsmoker or anyone with a computer dyno, can you tell me about how much horsepower I will have after this rebuild on a <a href="http://www.motorhaven.com/">390 </a>conversion? Here is what I have done to the engine:
<a href="http://www.motorhaven.com/">390 </a>crank C1ae with c7ae-b rods
Bored .030 with H304p's should be about 9.5:1
Standard heads c8ae-h (about 70 cc ) rebuilt but not ported
Melling cam .514 lift Intake/exhaust with 310 dur (224 at .050)
True roller timing chain and comp cam roller tip rockers
Edelbrock performer <a href="http://www.motorhaven.com/">390 </a>intake
<a href="http://www.motorhaven.com/">Holley</a> 670 street avenger
Electronic Ignition pertronics set up and Msd Ignitor box
C6 tranny with shift kit and Daaco 2500 stall
Aluminum driveshaft( no carrier bearing anymore)
3.5:1 9" (still open)
Anyone know what this is putting out?? This is going in my 69 f100.
Old Mar 27, 2003 | 05:09 PM
Ratsmoker's Avatar
Ratsmoker
How much hp???
Need a little more precise info to make the dyno as accurate as can be. Valve opening and closing event degrees are the best. If you don't have this info I will make a good guess.
Old Mar 27, 2003 | 05:14 PM
Jsbiohazard
How much hp???
If you mean the separation on the cam lobes I believe it was 110 degrees but I dont have the cam card handy(across town with truck) Otherwise make a guess, your guess would be much better than anyone I would give.
Old Mar 27, 2003 | 05:20 PM
Ratsmoker's Avatar
Ratsmoker
How much hp???
Do you happen to know the intake centerline?
Old Mar 27, 2003 | 05:33 PM
Jsbiohazard
How much hp???
Ok, I found the specs for the camshaft RS,
duration @.050 Intake/exhaust 223
Adv Dur 307
Valve lift In/ ex .514
Center line Int 110 Ex 114
Cam lift In/ex .292
Rocker ratio 1.76
The melling part number is 24218 class II cam power range is 2200-5700 need a stall atleast 2200. Also I will be running headers.
Old Mar 27, 2003 | 06:08 PM
Ratsmoker's Avatar
Ratsmoker
How much hp???
Check the sticky at the top of the forum.
ba 302
1978 - 1996 Big Bronco
Mar 12, 2009 03:59 PM
orangeford
Apr 1, 2003 10:54 AM
wesley958
Mar 30, 2003 08:15 PM
twix4x4
Mar 28, 2003 11:38 AM
66MercMan
Mar 26, 2003 07:08 PM
