RTV vs bubber seal
Old Jun 23, 2011 | 10:58 AM
pres's Avatar
pres
RTV vs bubber seal
'56 truck shop manual states to use a rubber seal when replacing the starter. Can I use blue RTV? If not, where can I get a rubber seal?
Old Jun 23, 2011 | 02:57 PM
Old F1's Avatar
Old F1
What or where, is this rubber seal?
Old Jun 23, 2011 | 08:07 PM
pres's Avatar
pres
Thanks for responding.
Between the starter and clutch housing.
Old Jun 23, 2011 | 09:04 PM
Old F1's Avatar
Old F1
So I looked in my 54 parts book and couldn’t find a seal listed (although that doesn’t mean much) and I can’t remember ever seeing one but when you think about it, what is it sealing, there are no fluids on either side, if its just to keep dirt / dust out then a little silicone would be fine. (subject to correction)
Old Jun 23, 2011 | 10:15 PM
ALBUQ F-1's Avatar
ALBUQ F-1
It might interfere with grounding if you put it on the face of the starter
Old Jun 24, 2011 | 11:06 AM
dmptrkr's Avatar
dmptrkr
Starter To Flywheel Housing Seal - 239, 272 & 292 V8 With 11" Clutch - MAC's Antique Auto Parts
RTV might make it difficult to remove the starter next time.
Old Jun 26, 2011 | 12:42 PM
wmjoe1953's Avatar
wmjoe1953
Yes, there is a rubber dust seal that goes around the nose of the starter. It's just a dust, and moisture seal to keep crap out of the clutch housing. I'm with Ross, silicone could interfere with the grounding of the starter, unless you attach a ground strap at one of the starter bolts. The seal is available in reproduction. I actually almost bought one for the '54 I'm restoring, but the original was still completely intsct and not brittle. I believe it was Mac's over in New York that had them listed, but I would have to verify that.
Old Jun 26, 2011 | 03:47 PM
52 Merc's Avatar
52 Merc
I can see where a dust boot might be beneficial if the truck was driven and used like a truck, in fields and dirt roads, like life was 60 years ago. But the way these things are driven and cared for today, I don't think not having one there would be a big deal. I've never seen one on any other, more modern application. Personally, I wouldn't worry about it. And I certainly wouldn't put silicone on the end to seal the bellhousing.
My 2c, fwiw.
Old Jun 27, 2011 | 04:13 PM
pres's Avatar
pres
Thanks for all the posts. I'm just going to slap it together without the seal.
Good to know about grounding issue and MAC's.
pres
Skandocious
31
Aug 3, 2024 06:27 PM
granny_rocket
Oct 23, 2013 10:47 PM
carriljc
1978 - 1996 Big Bronco
Dec 16, 2012 11:19 AM
Finger__Rachet
Dec 9, 2012 10:00 AM
351slug
Feb 14, 2011 08:33 AM
