front differential gear ratio question
Old Dec 5, 2002 | 10:05 PM
rrcktrog's Avatar
rrcktrog
Hello fellow enthusiasts.
I have installed a '79 F-350 4x4 axle on a '90 E-350 van and I need to verify the gear ratio.
I have not been able to find a tag on the axle housing and have a number from the ring gear. The problem is that I am not sure what this number is stating.
12 13 73 DANA 620108A A30D304-10
Can anyone tell if this gives me enough information to determine the ratio?
Old Dec 5, 2002 | 11:14 PM
MustangGT221's Avatar
MustangGT221
It looks like 3.73, but never use 4wd if the axle ratios arnt the same, they must be within 1% of eachother. An easy way to get an idea as to what it is, get the front tires in the air and put a mark on the driveshaft so you can see it from the tire. Turn the tire once, and if the shaft turns 3 and 1/2 times it's around 3.55. If it's between 3 and 1/2 and 4, it's probably 3.73. If it's more than 4 times, but less that 4 and 1/2, it's probably 4.10s...etc etc.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Justin - One Happy FTE Member
Old Dec 5, 2002 | 11:49 PM
steve83's Avatar
steve83
Dana can tell you:
http://www2.dana.com/Expert/wc.dll?DSD~demenu~DEMENUA~
Old Dec 6, 2002 | 11:05 AM
StrangeRanger's Avatar
StrangeRanger
If it's an open diff, you need to jack up only one wheel on on the axle and turn it 2 revolutions and count the driveshaft revs. If it's a limited slip you jack up both wheels and turn them through 1 revolution.
Old Dec 7, 2002 | 11:17 AM
MercMan's Avatar
MercMan
Old Dec 8, 2002 | 10:55 PM
dsh82's Avatar
dsh82
Have you driven the van in 4 wheel yet? If so, and your truck isn't dead yet, just look at what the rear is. Has to be the same.
Dan
'95 F150 Eddie B
Heavy Duty Springs
32 BFG AT KOs
3.73's w/ trac loc rear
smittybilt push bar w/ 2 KCs
clearance lights and custom fogs
System One racking
"A mean work truck"
whitley
21
Jul 14, 2020 09:15 AM
deezdrama
Sep 1, 2016 08:16 PM
Selfhl1
19
Oct 23, 2015 08:44 AM
DILLIGAF13
Offroad & 4x4
Oct 18, 2008 01:11 PM
