compression test on 95 302
Old Mar 27, 2003 | 04:20 PM
mstaser's Avatar
mstaser
Question compression test on 95 302
What is the compression supposed to be on my 1995 F150 302.
I can't find it anywhere.
Old Mar 27, 2003 | 07:04 PM
PigFarmer's Avatar
PigFarmer
Stock should be about 8.9/1
Randy
Old Mar 27, 2003 | 10:09 PM
steve83's Avatar
steve83
The actual pressure (ideally) should be the compression ratio times your local atmospheric pressure (14.7psi at sea level). So if the stock spec is 8.9:1 and you live in New Orleans, you should see ~131psi.
rlay302
Dec 9, 2012 01:06 PM
IsoGrifo
Oct 16, 2009 06:37 PM
ymeski56
Oct 20, 2008 06:51 AM
shuttlevalve
Jun 7, 2007 09:09 PM
motorheadmach1
Apr 21, 2003 04:09 PM
