1978 - 1996 Big Bronco
Trans compatability
Old Jun 23, 2011 | 07:17 AM
vinf100's Avatar
vinf100
Trans compatability
Overheated my E4OD in my Bronco with 5.8L ,cannot find a used one locally .Plenty of 2-wheel drive ones available ,anyone know if a 2-wheel drive will work ? maybe just a matter of removing tailshaft housing ?
Old Jun 23, 2011 | 08:20 AM
greystreak92's Avatar
greystreak92
You should be able to swap tailshaft housings AND tailshafts. E4OD has it bolted on unlike some other trans models that have cast as part of the main casing.
Old Jun 23, 2011 | 01:40 PM
hav24wheel's Avatar
hav24wheel
BUT, I believe inorder to swap tailshafts you have to take whole trans apart
Old Jun 23, 2011 | 05:24 PM
fordbroncodave's Avatar
fordbroncodave
yep tail should be compatible. if not or too much work, sell the trans or return it. you got nothing to lose because you can't drive your truck right now anyways
Old Jun 23, 2011 | 08:07 PM
kenpobuck's Avatar
kenpobuck
Yes, to swap it over you need to pull the trans apart starting at the front.
Old Jun 27, 2011 | 08:52 PM
vinf100's Avatar
vinf100
special tools?
is it a job that requires special tools ? ive never done auto tranny work before , but understand that it can be done without a degree
Old Jun 28, 2011 | 01:47 AM
hav24wheel's Avatar
hav24wheel
Yes there are a couple special tools, what they are for that trans I have no idea.
Old Jun 30, 2011 | 08:41 AM
fordbroncodave
take lots of measurements of the shaft on your broken transmission then just bolt on your tail housing to the 2 wd trans and re measure to see if they are the same dimensions.
if not...
tear your broken trans down to the point you can get the shaft out or if you can get that far with basic tools
