starter stuck engaged
Old Jun 23, 2011 | 04:43 AM
GreaseMonky's Avatar
GreaseMonky
Ok, I have done some research and think I may have found my issue, but wanted to ask you guys,
First tho I gotta let you know im doing this from my phone while its 5 a.m., and I'm stranded 1500 miles from home
Ok so I was helping a friend load some stuff on his truck and we where using my headlights, got all done and went to start truck, cranked slow and starter stuck, jumped out and disconnected my batterys, as soon as I hooked them up, it cranked again, but real slow, while the key was off, crawled under the truck and tapped on the starter everything was fine hooked up jumper cables waited 15 minutes fired right up, shut it down tried to start, cranked fine, almost fired, went to start again, got slower, and van stuck again.
What do I do, just charge the batterys, or do I need to put a starter in also?
Old Jun 23, 2011 | 06:11 AM
427 fordman's Avatar
427 fordman
I'd just charge the batts, if that seems to work then maybe for security since you are so far from home, get a starter from the parts store for the ride home just in case. If you end up not needing it, return it to the same named parts store where you live.
smashclash
47
May 11, 2023 09:04 PM
jed1894
23
Nov 28, 2016 08:18 AM
irishredcoat
24
Jan 26, 2016 03:59 PM
AtlM5
Dec 13, 2015 07:57 PM
Greg Castro
Mar 10, 2012 06:39 PM
