Gearing?
Old Jun 23, 2011 | 12:04 AM
hedhntr's Avatar
hedhntr
Gearing?
I want to change from 410 to 373 for awhile and thought rearend swap instead of a gear change what years of rearends would fit on my 97 and could I even just swap it with out doing anything else thanks
Old Jun 23, 2011 | 12:25 AM
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
Two wheel drive or four? If you have a 4x4 and just wanting to change the rear for a test there would be no problem as long as you didn't use the 4 wheel drive. It would be a little bit of a PITA to change the rear end because you would have brake lines to deal with. Either way it is a PITA but I guess if you have a rear end to try already I guess it would be OK. But the way you ask about years that fit (and I don't know what years that fit) I would say make the decision on what ratio you want and do the gear change and hope your right.
Tim
Old Jun 23, 2011 | 02:13 AM
joe_13894's Avatar
joe_13894
The last year you can use is a '97. Ford changed to a metric lug pattern for the superdoody.
Mid year 92 Ford changed the length of the pinion shaft. If you use one older than mid 92 you may have to change the drive shaft. It also isn't as strong.
Single rear wheel or dually? The dually changed lug pattern in '89. The single rear wheel changed a LONG time ago.
Old Jun 23, 2011 | 06:17 AM
427 fordman's Avatar
427 fordman
FYI, ford never offered the 3.73's in the rearend of our trucks. You'd either have to put them in yourself or like mentioned a super duty one has different lug pattern to use. 3.73's weren't offered till 99. Unless you get lucky and find one where someone already has done a swap
Old Jun 23, 2011 | 12:15 PM
joe_13894's Avatar
joe_13894
What he said
I forgot that important part. The 10.25 only came in 4.10 or 3.51. There are 3.73 ring gears easily available but then the issue of gear setup enters in. 3.73 is a good ratio for our trucks as long as you don't haul heavy.
Old Jun 23, 2011 | 12:38 PM
dclack's Avatar
dclack
Originally Posted by joe_13894
You mean 4.10 and 3.55. 3.73s came in the Sterling/Ford 10.5 on the 99 and newer trucks. You could put a 10.5 in your truck but the spring perches have to be moved and the bolt pattern is metric; so your rims won't fit. You can also put used 10.5 ring and pinion in your 10.25, that's what I did. But to make it profitable, you have to do the install yourself, a shop will likely cost $600+ just for labor.
plgebbia's Avatar
plgebbia
What he said
I forgot that important part. The 10.25 only came in 4.10 or 3.55. There are 3.73 ring gears easily available but then the issue of gear setup enters in. 3.73 is a good ratio for our trucks as long as you don't haul heavy.
Fixed it for you
Old Jun 23, 2011 | 12:41 PM
plgebbia's Avatar
plgebbia
dclack beat me to it! again!!!
Old Jan 5, 2014 | 12:00 PM
m zoll's Avatar
m zoll
373 vs 410
is there a big change in MPG from a 373 to 410 ?
Old Jan 5, 2014 | 01:41 PM
444dieselrod's Avatar
444dieselrod
NO...My ext cab Auto with 4:10's gets 16. My crew cab 5-speed with 3:55 gets 17.....I put 3:55 in my ext cab for a year and still only got 17.....Towing is the only real advantage to the 4:10's or disadvantage to 3:55's...
Diesel Rod
Michaelshawnbradford
18
Oct 2, 2014 04:31 PM
Eladhsoj
Sep 11, 2013 05:49 PM
Lilryan
Mar 14, 2013 07:52 PM
Alvinmac
Jul 4, 2010 06:31 PM
Alter Ego
26
Mar 22, 2009 10:42 AM
