High Flow Convertors
Old Jun 22, 2011 | 07:09 PM
TexasGuy001's Avatar
TexasGuy001
Question High Flow Convertors
I've wanted true duals on my truck for the more than 10 years I have owned it. It needs new cats anyway. I wish we didn't have sniffer test here. So I am now finally going to do it. I'm going to run a pair of Dynomax Ultraflo mufflers. I think this would be a great setup for the future 351W.
Here is my question. I'm wondering what everyone has been using for high flow cats. I have looked at the Magnaflow ones. A couple of shops have told me that Cherry Bomb cats are good. I would like some small/short 2.5 inch ones. Which ones are good and which are not so great?
Also, Do I need to plumb the AIR pump to connect into the pipes before both cats or do the new high flow cats not need it?
Old Jun 22, 2011 | 08:23 PM
Edgethis's Avatar
Edgethis
Most new 3-way cats will not require or benefit from the air injection. It wont hurt them to get the air, just won't affect the cats either way, good or bad.
Old Jun 23, 2011 | 10:21 AM
TexasGuy001
Thats good to know. I may still try to get it connected to both sides.
Does anyone have any suggestions on what brand to buy. I was also looking at Catco.
Old Jun 23, 2011 | 11:09 AM
rla2005's Avatar
rla2005
I love the Magnaflow spun series converter I used on my '92 F350 w/5.8L engine. For a 2.5" application I recommend the MagnaFlow Catalytic Converters - 49-STATE & CANADA 59926
Old Jun 23, 2011 | 12:11 PM
Conanski's Avatar
Conanski
I have a Magnaflow cat on my truck now that is falling apart.. the honeycomb is loose and rattling around inside.. and it's only a year old give or take so I'm not that impressed with it.
Old Jun 23, 2011 | 12:18 PM
Jason Lewis's Avatar
Jason Lewis
I got the Magnaflow y with cats 3 1/2 years no probs ty has seen them on my truck, however i have read peoples bad storys about them, im gonna look today at them thay have been flawless (Texas Truck) so salt roads
My exhaust guy uses Catco
Old Jun 23, 2011 | 02:02 PM
strokin'_tatsch's Avatar
strokin'_tatsch
I was concidering using Random cats. Still haven't decided between Catco and Random, but something to look into.
Technical
Old Jun 23, 2011 | 03:53 PM
rla2005's Avatar
rla2005
Which model did you get Paul? The spun series model I purchased has a metallic substrate instead of ceramic. 2 years on it with no problems so far.
Old Jun 27, 2011 | 02:55 AM
TexasGuy001
I'm curious to know the same thing as RLA.
Old Jun 27, 2011 | 09:41 AM
Conanski's Avatar
Conanski
I have two magnaflow cats actually.. the newer one is a 94000 series oval universal and that is the one that is coming apart, the older one is a 54000 series round and it's still solid.
Old Jun 27, 2011 | 02:15 PM
rla2005's Avatar
rla2005
Ouch.... That is not a very good story at all. Perhaps a bad batch or someone "drop shipped" it before you received the newer model.
Old Jun 28, 2011 | 10:44 AM
White Max's Avatar
White Max
I've used the Catco and Magnaflow/Carsound cats on my vehicles. I haven't had any trouble with either brand, though the Magnaflow/Carsound pieces appear to be of higher quality.
Old Jun 28, 2011 | 01:00 PM
Bankrupter's Avatar
Bankrupter
White did you use that 2nd cat in the pic you gave me
Old Jun 28, 2011 | 01:05 PM
White Max's Avatar
White Max
Nope, I'm just running the front cat on that y-pipe. The second cat is sitting on a shelf here.
Old Jun 30, 2011 | 11:14 PM
TexasGuy001
Technical
I have not heard of Random cats. What do you know about them?
Island Time
Oct 23, 2014 09:49 PM
darkmage55
1997 - 2003 F150
Jul 22, 2010 07:41 PM
Skandocious
Apr 29, 2007 06:36 PM
epark1321
1997 - 2003 F150
16
Nov 26, 2006 11:50 PM
jamiew
Mar 5, 2001 09:48 PM
