He bought it used and found out recently, that he does not have a key to the spare tire lock mechinism at the rear of the truck. and had been told that ford does not sell them.
Any sugestions or help would be appreciated.
His initial investigation leeds him to believe that he has to cut the cable to get the tire down to take apart or dismantle the lock.
Thanks all
Jim G 1098
Reason: Spelling
If you want to fix it, instead of aborting it, don't use that method.
Ford does not sell the keys. McGard does. But there are about 20 different keys, so you need to know which one your truck has. For that you go to your Ford dealer and ask them to try their master set and show you which one it is. You might need to ask the service manager, because they keep the master set locked up for obvious reasons. Also, some smaller dealers may not have them, but larger dealerships should.
Once you know the code, just go to the McGard site and order the key. I think it cost me about $30. It's really not that hard to do it right. Don't know why so many people screw up their locks.
As I understand it, you can pull the lock off of the end of the winch crank and then the jack crank tool will fit right in and you don't need a key anymore. It's hard to reach up around there, and you have to move the tube out of the way, but it can be done.
Of course, then you don't have a lock. But I doubt spare tire thieves care much about locks anyway.
If finding a key is a problem, do what my Ford dealer did for me. Pull the 'keyed insert' out and the space it was in is now turnable with a 3/8" drive.
Thanks to all for their help on the spare tire lock issue.
Went uo to NY this weekend and took care of it with the suggested 9/16ths Poped right out after lowering
I know I'm bringing a thread back from the dead here, but I found an alternative method today that some people may find useful. I bought my '13 F250 last week with only 6K miles on it, and whoever had it before me had already lost the spare tire "key". I don't like the key anyway, so I decided to get rid of it. I used a simple method requiring two tools, a big a** flathead screwdriver and a dead blow hammer:
Took me about 5 minutes to assess the situation after removing the plastic funnel shaped guide (just twist and pull, it takes almost no effort) and about 30 seconds to do the job. Looking in from the rear passenger side wheel well, push the big a** screwdriver into the hole that has the big red arrow pointing at it in this pic:
Once you get the screwdriver almost all the way in, position it so that the flat part of the head of the screwdriver has a good bite on the side of the lock. Give it a solid whack (or two) with the dead blow hammer and it pops right out. The offending lock:
Never had a problem with stolen spares around me. Now I can just use the jack tools that came with the truck to drop the tire and I don't ever have to worry about losing the key.
<table border="0" cellSpacing="6" cellPadding="0" width="100%"><tbody><tr><td noWrap="nowrap">Thats a great alternative Diabolical.
I tired the 9/16 socket that some folks say work.
I tried the bolt extractor that some say worked.
I would up using a gas pipe with a large cotter pin clipped on the end. After banging the pipe onto the lock, I was able to lower the tire by hand with just turning the pipe. After I pulled the pipe out, the lock came with it. So now, basic tools will do it.
