Ok, im a huge junkyard prowler and fan when it comes to parts that i need for my trucks. One very huge question i have is what automatic transmissions from others ford will bolt up to my truck?
Mine is a 2000 F150 5.4L 4x4 non 7700 gvwr type 137,000 miles
the transmission began by not shifting into overdrive, then moved on to having nothing but reverse the next day, to not going anywhere at all! im asking about interchangeability options being that i dont have $2000 to get mine rebuilt, and not a single junk yard near me in WA state has a 4r70w for a realistic price. $1300 dollars used is rediculous.
i have seen posts saying possibly one form a 4.6l
or one form a explorer possibly
as well as i think the e350 has one...
my main concern is finding another vehicle that has a transmission with the same plugs as mine as well as ability to handle the power, so i can offer the junk yards more vehicle options to search for. most of them just hear 2000 f150 and instantly say no..
please can anyone help me out?
The electronics changed from '97-'98. You're pretty much stuck with a 4WD 4R70W though. This leaves you basically 2 choices. Find a used 4WD F150 trans, or rebuild yours. You could buy a low-mile used 4R70W from anything '98-up, and then gut it to transplant the internals to your trans case. I found a smoking deal on some V6 Mustang 4R70W's a few years ago with less than 5K miles on them, and bought 3 of them to use for rebuilds. I scrapped the cases a few months ago, but the transmissions that I transplanted the internals into are still going strong today. One of them is in my Tbird, and the others are in Tbirds that are supercharged. One advantage to tearing it down and going through it yourself is that you can add clutches and make minor mods that will increase the clutch capacity and overall durability while you have it apart.
JL
Also the 4R70W from a 5.4l powered truck is built heavier internally than a 4R70W from a 4.6l powered truck.
How much heavier of a build i do not know, but there are some differences. But as previously stated they will bolt up and work either way.
One thing about using a 4.6l converter with a 5.4l engine. It makes for some sweet burn outs and reving power, but i did notice that i was loosing some bottom end grunt out of the whole when towing. I think since the 5.4l engines peak torque is at 2500 rpm, and the 4.6l stall is around 1800 rpm, you are missing some of the power band of the 5.4l.
Just my .02
The planetary is different (stronger gearset-it's hardened differently), and there is a different wave plate in the forward clutch. That's it.
JL
Johnny, how long would you say it would take you to rebuild your own trans? Its the only thing that I have never rebuilt before and I'm thinking of tackling it in the very near future.
Rich
Rich
I can do one in a couple of hours easily. But I've been inside so many of them working on them for friends that they're pretty easy now. For a newbie following the good manual-you're looking at 3-4 hours easily. You'll also need a couple of tools to do it without alot of cursing and cut fingers.
JL
Thanks for the info! Cursing? Whats that? LOL Is it "specialty" tools that you need? Any book you reccommend?
Thanks
Rich
It depends on how deep you're getting into the trans. If you're rebuilding an existing trans, then you'll need the lip-seal protector kit (about $80), a clutch spring compressor (about $100), and some various other odd and end tools-most you can make yourself.
You'll need a set of slide hammers to pull the front pump, and the only manual I'd recommend is the Helms 4R70W manual. It's expensive, but it's detailed like no other,and doesn't miss anything.
JL
Looking into this as well. I'm going to start a buildup of my 5.4L this summer/winter and I'd like to find a blown 4r70w or 4r75e to rebuild with higher end stuff and a shift kit. Is there a comprehensive parts list with Ford numbers so one can just order all the stuff needed to do a full rebuild? The 4r75e is another option but IIRC there are a few things you have to do to get it to work in place of the 4r70w. What those are I need to do some more research...
The 4R75 is stronger and has all of the better/upgraded 4R70W parts in it.
Whatever you do-DO NOT use any aftermarket clutches that are not OE spec. Those crap Alto Red and Raybestos blue clutches are not any good. There is absolutely no need for any type of "shift kit" in a 4R70W.
An excellent reference is here: http://tccoa.com/articles/tranny/tra...on/index.shtml
JL
05/06 Expeditions had it, I think the F-150s do too after 2004 but not completely sure. Yeah it is stronger and shifts smoother.
Good to know, I would only use OE stuff in a trans anyway. Do you know if anything crazy is required to make the 4R75 work or is it basically a bolt in upgrade? I know of at least 2 people on another forum with their 4R70Ws swapped for the 4R75 but I can't get ahold of them through PM.
It replaced the 4R70W in 2004.
It's essentially the same trans, but it has many internal updates that make it more durable.
JL
