Spitting massive oil?
Old Jun 30, 2011 | 01:36 PM
PaysonPSD's Avatar
PaysonPSD
Check your PMs.
Old Jul 5, 2011 | 09:14 AM
Steve_250's Avatar
Steve_250
The tool was easy to make out of scrap metal.
I got the o-rings from Diesel O-Rings Wednesday and received them Friday via 4-7 day regular mail.
Wow, all I can say is thank you for the very fast delivery!!!
In the instructions in the package and in this thread, it says to push the hose in and then insert tool.
There is zero play between the fitting and the hose, it did not release.
I tapped on it a little to try and jar it loose. Failed to release.
Any other methods?
Old Jul 5, 2011 | 10:27 AM
PaysonPSD's Avatar
PaysonPSD
Slip the tool behind the black collar without pushing on the hose. Using the disconnect tool push the collar toward the fitting and pull on the hose. Hose should pull free.
Old Jul 5, 2011 | 11:08 AM
Steve_250's Avatar
Steve_250
No dice....
Dang thing seems to be locked tight.
It's the front one, as depicted in the pic, limited access.
I go past a friendly rural dealer, been trying to sell me a 2011, I'll ask them about doing it.
I can't keep trying as I lose oil.
I'll wind up spending more in oil than in a little dealer labor.
Old Jul 5, 2011 | 11:15 AM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by Steve_250
No dice....
Just to clarify the collar has to be pushed toward the fitting on the HPOP and the hose must be pulled straight out or it will bind and not release.
Old Jul 5, 2011 | 11:20 AM
Steve_250's Avatar
Steve_250
Yep, tried that.
I'll stop in and see what they want to do it.
Old Jul 5, 2011 | 03:22 PM
bulla's Avatar
bulla
There is a vid on here showing how it works. Someone is bound to have it in their links!!
Also try a different one and see if you can get 1 of the 4 off. This will at least get you the concept!
Old Jul 8, 2011 | 11:10 AM
Steve_250's Avatar
Steve_250
I went to the dealer.
He changed two rings, topped off the oil and cleaned the engine.
Only charged me for 30 minutes.
I popped the hood the next morning to do a good cleaning at home.
I was amazed, it was showroom clean!!!
Very good experience at this dealer.
Prince Frederick Ford in Maryland.
Mechanics were James and Steve.
Service adviser was Johnnie.
It was well worth the fifty bucks.
I'll let them chance the other two when I have time.
I appreciate the help y'all gave me.
Hopefully I can find that video.
Old Jul 8, 2011 | 11:14 AM
cj45lc's Avatar
cj45lc
Glad you got it fixed & good to know there are some good guys working at the Ford place
Old Jul 8, 2011 | 11:48 AM
PaysonPSD's Avatar
PaysonPSD
He chanced two rings, topped off the oil and cleaned the engine.
Great service. Reps to Prince Frederick Ford in Maryland, as well as Johnnie, James and Steve. Hope they used some Loctite 680 on the threads.
Rig boss
6.2L V8
13
Mar 20, 2017 02:35 PM
Robert Green
Dec 11, 2015 11:24 AM
63' f100
May 29, 2012 10:09 AM
pullinair
19
Oct 5, 2008 09:56 PM
jahmo55
1997 - 2003 F150
13
May 5, 2004 09:07 AM
