Emmisions icon
Old Jun 21, 2011 | 08:12 PM
Diesel Man 03's Avatar
Diesel Man 03
Emmisions icon
To day the engine icon (emmisions) light came while driving and the engine started to miss real bad.After I shut it down and restarted it it ran find, does anyone have an idea what it could be? The truck is an 03 SD with the 7.3 and has 79000 miles and isn't used a lot except when I pull our camper.
Old Jun 21, 2011 | 08:24 PM
F350-6's Avatar
F350-6
How rough did it run? Sounds like a UVCH issue. Do you have an ohm meter? https://www.ford-trucks.com/forums/8...ck-shakes.html
Old Jun 22, 2011 | 08:34 AM
Diesel Man 03
It ran on possibly 3or4 cylinders, I will check the connections on the #8 injector and see if it is loose.
Old Jun 22, 2011 | 10:04 AM
kccatpower's Avatar
kccatpower
i had a similiar problem with mine and a cps fixed it. i would still check your harness out as stated above.
