Compression Test Prep Question
Old Jun 21, 2011 | 02:03 PM
darkstar8's Avatar
darkstar8
What is the proper way to disconnect the ignition coil and fuel injectors for a compression test? I have a 1990 F150 302 EFI.
Old Jun 21, 2011 | 02:08 PM
RJR99SS's Avatar
RJR99SS
Just pull the fuel pump fuse, and unhook the coil wire on the distributor.
Or if you want you can just pull every injector's connector....if you're worrying about wasting the little bit of gas in the fuel rail.
Old Jun 21, 2011 | 02:45 PM
darkstar8's Avatar
darkstar8
Ok, thanks. Not worried about wasting gas, just don't want to muck anything up! Was reading somewhere that you can damage the coil if it builds up too much charge with no where to go?
cowmilker08
Indiana Chapter
May 2, 2013 09:42 PM
dpoc
1983 - 2012 Ranger & B-Series
20
Dec 4, 2012 11:14 PM
dieselaholic
Jul 13, 2011 12:52 AM
66 POJ
Dec 29, 2006 05:21 PM
smiller4597
Nov 13, 2005 09:44 PM
