Sponsored by: Real Truck
trailer brake controller
Old Jun 20, 2011 | 08:08 PM
cliffordredfx4's Avatar
cliffordredfx4
I have an 05 F-250 that I will be using to tow my new camper. I have never had a trailer with brakes so I will now be adding a brake controller. Is there a plug under the dash to plug into? My truck came with an adapter plug but I have no idea where it goes! Help!!!!
Old Jun 20, 2011 | 08:32 PM
RV_Tech's Avatar
RV_Tech
Under dash near radio. plug and play.
Steve
Old Jun 20, 2011 | 09:22 PM
5.4f250sd's Avatar
5.4f250sd
Do a search on here, it will really help! They are below the radio next to the upfitters or your cubby for your phone or wallet. It is really simple and like he said above it is plug and play!
Old Jun 21, 2011 | 02:02 PM
cliffordredfx4
The only plug I see is the diagnostic plug. Is it behind a cover?
Old Jun 21, 2011 | 02:09 PM
senix's Avatar
senix
If you have not gotten the controller yet, get a prodigy. Top of the line but well worth it.
Old Jun 21, 2011 | 02:36 PM
cliffordredfx4
I found it. I will be checking out the prodigy because everyone seems to love it!
Old Jun 21, 2011 | 07:58 PM
5.4f250sd's Avatar
5.4f250sd
Yes it is clipped to the back of the cubby...you have to take the drivers glove box out to get to it. Do a search it will help!
Old Jun 21, 2011 | 10:37 PM
cliffordredfx4
Is there power out of the 7 round plug that will run the interior lights on the camper?
Anyone know what the difference is between the prodigy P2 and P3?
Old Jun 22, 2011 | 04:59 AM
senix's Avatar
senix
P3 is the one to get.
The P2 you have to go thru too many steps to change the settings.
P3 now is all digtal and everything is right there.
Old Jun 22, 2011 | 07:26 AM
raidscsi's Avatar
raidscsi
On a 2000 F250 the connector is not where everyone seems to think it is. My trailer connector was directly in the center of the truck attached to the firewall, about 4" above the carpet behind the center console.
I had to take the garbage bag/purse hook and reach in through there. I will get pictures of it because I couldn't find anyone else who has a connector like mine.
Also I bought a Prodigy P2, from etrailer.com which had some good install videos. The P2 is way better than my Dad's cheap delay controller on his F150.
Old Jun 22, 2011 | 07:34 AM
raidscsi's Avatar
raidscsi
Wait, what? The thing has 3 controls, [Power ****][Manual Lever][Boost toggle button]
It took less than 5 minutes to setup the controller to the right settings for what felt good on my trailer. I use the P2 all the time with my only trailer and it works fine and is easy to use. Not sure what the P3 gets you that the P2 doesn't have, but ease of use can't be one of them, because it can't get any easier than the P2.
Old Jun 22, 2011 | 10:15 AM
WestCoastTodd's Avatar
WestCoastTodd
That would be great - I've got the same truck, also need a controller.
Old Jun 22, 2011 | 11:58 AM
raidscsi's Avatar
raidscsi
I bought my controller from eTrailer.com, which wasn't the best price, but like Newegg.com they have really good customer service.
Tekonsha Prodigy P2 with Ford Adapter
Tekonsha Prodigy Proportional Brake Controller with Ford Adapter Tekonsha Brake Controller with Wiring 90185-3035P
Their video for a 2000 F250 shows the connector mounted inside the driver side under dash area on the far right. My truck has a mounting hole in the metal for the connector but it wasn't there.
Trailer Brake Controller with Wiring Installation - 2000 Ford F-250 Super Duty Video | etrailer.com
I found my connector just on the other side of that metal panel, but I could only reach it through the purse holder cutout thingy.
Also interesting to note is that something on the steering column is wired up using the same connector style. I found a connector near the steering column that was used, but the same shape and style as the brake controller connector.
View through the purse holder into the dash, the metal it is mounted to is visible from the driver side compartment, and I could reach in and touch the connector but not actually push the connectors together.
Closeup of the connector itself.
I havent finished or mounted anything yet. Right now I just have the plastic docking collar on the controller and it wedges perfectly into the small cubby on the left. I think that is where I will end up mounting it permanently... by drilling a hole to hide the wire..
Anyone know where I can get the OD switch cover?
Old Jun 22, 2011 | 12:11 PM
dchamberlain's Avatar
dchamberlain
The brake controller plug changed in 2005. It can get confusing, because many suppliers note different part numbers but inconsistently apply them to model years and such. Up to 2004, you want the Tekonsha 3035-P wiring harness. From 2005 to 2007 you want the 3065-P harness, and apparently from 2008 on you want a 3034-P harness.
I got this information here. You might want to check it to make sure you get the right harness.
Brake Controllers - Tekonsha
Old Jun 22, 2011 | 12:15 PM
WestCoastTodd
That's excellent, thanks! Looks easy enough.
Funny, my shift lever looked just like that. The wires to the overdrive switch/light were cut in the steering column though, so I ended up just replacing the whole shifter. Wasn't cheap, but not terrible either.
