I am stumped, need some help!!!!
Old Jun 20, 2011 | 07:45 PM
Old 4x4's Avatar
Old 4x4
Hi everybody,
I just removed my old door hinges on my 77 f-150..The bolts that I removed will not thread back into the plate in the A- pillar.....I cant figure it out....If I take a Fender bolt (5/16-18) it will go in..
The factory hinge bolts that I thought were the same size, and were just removed from the same holes will not thread back in..
The end of the Factory Door hinge bolt is much fatter then the fender bolts, basically the same size as the thread. ..They will not grab the threads as if they were too big......
What size thread are the hinge bolts?.. please help...I have never had this issue...
Ps...The threads are not torn up, just weird...
Old Jun 20, 2011 | 09:49 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Did the nut plate move?
Old Jun 20, 2011 | 10:09 PM
Old 4x4's Avatar
Old 4x4
No, had to heat and remove the bolts from the back of the plate because they snapped off, im thinking that there is ridge of rust stopping the bolts from going in....I just need the proper thread size...I think that its slighty bigger then 5/16-18....
Old Jun 21, 2011 | 01:37 PM
Old 4x4's Avatar
Old 4x4
I believe that they aer 5/16-18, Im pretty sure now that the stock door bolts were used to actually tap the nut plates....
Old Jun 23, 2011 | 12:17 AM
four-sixty-power's Avatar
four-sixty-power
get a tap and die set (or just the size you need that matches the bolts you took out) and run them over the bolts and into the plates to clean up all the threads.
you never know what will work until you try it
Old Jun 23, 2011 | 08:40 AM
650's Avatar
650
I had the exact same problem with mine. I tapped my cabs plate the hinges bolt to and the factory bolts still woldn`t go in. I ended up having to use some steel 5/16 on 18 bolts.
Old Jun 23, 2011 | 11:01 AM
tbear853's Avatar
tbear853
They are 5/16-18.
A buddy had same problem on his Dent once. We ran a tap through the holes to clean the internal threads ...
... and then took the bolts themselves and gripped them in a pair of vise-grips and just slightly tapered the thread end on a belt sander followed with a wire brushing.
Wouldn't hurt to apply a dab of Never Seize.
Old Jun 23, 2011 | 02:59 PM
Old 4x4's Avatar
Old 4x4
Originally Posted by tbear853
They are 5/16-18.
Yea, it was weird..The factory door bolts are larger at the end and were originally run into the nut plate without any threads..Self tappers so to speak.......I got it repaired now....Thanks everyone
Old Jun 23, 2011 | 03:00 PM
Old 4x4's Avatar
Old 4x4
They are 5/16-18.
Yup, thats correct....Thanks
