Vacuum Hoses
Old Jun 20, 2011 | 12:43 PM
devino246's Avatar
devino246
Question Vacuum Hoses
It looks like one of the POs must have meddled with some of the vacuum lines. Wehn I bought it the PVS was broken and bypassed so I bought a new PVS and hooked it up the way I thought it might go. Now looking at the vacuum diagram under the hood, it looks nothing like it. Does anyone have a better diagram than the one under the hood? Also, im gonna get a vacuum gauge later. Where should I tie it in?
Has a cat and the plate on door jamb says the truck was ordered in Washington if that makes any difference.
EDIT: Oh great, theres no EGR valve on there
Old Jun 20, 2011 | 05:40 PM
fmc400's Avatar
fmc400
MSEE
If it's just a standard two-port PVS, then one port (doesn't matter which) goes to ported vacuum, and the other goes to the EGR valve. Ported vacuum is sourced above the throttle plates - what kind of carburetor is this?
A vacuum gauge goes to manifold vacuum - if you have a vacuum tree on your firewall or back of the intake, you can tie off there.
Old Jun 20, 2011 | 06:16 PM
devino246's Avatar
devino246
Its the 4 port, plus another 2 port. Forgot to mention: 1979 F150 351m, Motorcraft 2150
(two port is the little teal thing to the left of the distributer under the coil wire)
and heres the diagram which I can hardly make heads or tails of:
Old Jun 23, 2011 | 04:25 PM
devino246's Avatar
devino246
Ok, got it figured out. Now I just need to find a vacuum resistor. NumberDummy?
brooklyn
26
Nov 9, 2023 11:21 AM
45FMJoe
37
Jan 5, 2019 09:44 AM
OhMyFawd
Oct 3, 2016 01:11 PM
gillman.6
Jun 20, 2016 09:38 AM
grandpas1974
Apr 8, 2016 11:34 AM
