400 flywheel bolt pattern ???
Old Jun 20, 2011 | 03:42 PM
1FastGambler's Avatar
1FastGambler
Is the 400 flywheel clutch bolt pattern 3.558"?
Doing a ZF5 swap and need to confirm if a Centerforce - CFT261015 is the correct pressure plate.
Last edited by 1FastGambler; Jun 20, 2011 at 03:48 PM. Reason: provided better info
Old Jun 20, 2011 | 04:01 PM
evam350's Avatar
evam350
If you have the right flywheel for a 12" clutch then yes that will work.
Old Jun 20, 2011 | 04:15 PM
1FastGambler
Centerforce - CFT261015 will bolt onto the 400 flywheel?
Yes, the flywheel is for 12" clutch.
Thank you for the quick response!
Giltnane
Dec 16, 2015 06:27 PM
thomtim4
New Member Introductions
Sep 10, 2015 02:18 PM
dogdays
Aug 24, 2015 02:24 PM
mudrunner4ever
Mar 18, 2012 07:26 PM
