Down Pipe replacement diamond eye. Info need!
Old Jun 19, 2011 | 08:39 PM
dougbrown's Avatar
dougbrown
Hello Gang,
This weekend I'm going to atemped to replace my stock mpg robing down pipe with the diamond eye one I bough a while ago. I know I have cut and mod the body but how much? Also will regular steel sawzal blade cut the old one out?
Any info would be great!
Old Jun 19, 2011 | 08:49 PM
fordpride's Avatar
fordpride
mine i just had to cut and bend the seam.
get a good long blade
Old Jun 19, 2011 | 08:56 PM
dougbrown's Avatar
dougbrown
how did u bent the seam? Beat it with a hammer?
Old Jun 19, 2011 | 08:58 PM
Deadeye1445's Avatar
Deadeye1445
When Me and My Dad put mine in, we used a Porta-Power to bend the seam back.
Old Jun 19, 2011 | 09:06 PM
dougbrown's Avatar
dougbrown
Thanks Cody, Normally It be me and my dad but he working on the Farm this coming weekend and I Have to be home for saturday night! So I figured it be a good weekend to work on it. I will have to look at our porta-power!
Old Jun 19, 2011 | 10:21 PM
rodneywar's Avatar
rodneywar
i didnt have a metal blade long enuf to cut my dp so i used a demolition blade it cuts like a hot knife thru butter!
Old Jun 20, 2011 | 06:09 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Port-a-power is the tool of choice here.
Makes the job go sooooo much better.
Get long sawzall blades, too, will help cutting the old pipe.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Jun 20, 2011 | 09:45 AM
Brown Falcon's Avatar
Brown Falcon
Each truck seems to be different as far as clearance goes. On mine I just used a crow bar and a piece of lumber to bend the seam after I cut it and it fit fine, had to adjust some things so it didn't rub on the transmission lines.
Hardest part was getting the old one out... a good sawzall and good blades are necessary. (Don't use a battery powered one, lol)
Old Jun 20, 2011 | 10:01 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
NEVER use a torch. OK?
Old Jun 20, 2011 | 11:01 AM
dougbrown's Avatar
dougbrown
ok, well we will find out saturday! I know no on the torch!
Old Jun 20, 2011 | 12:16 PM
Jester444's Avatar
Jester444
You'll want to put the new downpipe in from the top if you want to avoid "modifying" the firewall. Sawzall works just fine but takes a while. You're gonna love the stock "smoosh pipe" you pull outta there. I have no idea what the engineers were thinking when they designed it that way.
Good Luck!!
Old Jun 20, 2011 | 06:00 PM
Brown Falcon
I had to stick the top half of the downpipe in from the top, then slid the bottom half up from the bottom.
Still had to bend the seem so it wouldn't rub.
Old Jun 20, 2011 | 08:05 PM
mq1shooter's Avatar
mq1shooter
x2 on what Evan has said...I had new blades and Porta Power...pry bar and 2x4...it went pretty well....
Old Jun 20, 2011 | 08:52 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
X3 what Evan said.
Old Jun 20, 2011 | 11:11 PM
Jester444's Avatar
Jester444
It took a lot of patience and wiggling (and a small amount of beating with a 2x4) but I got it in without bending anything. Maybe my truck is just looser than yours (giggity)
