built 460/wide ratio C6 swap into 79 F100
I am here on and off, and here again. Quick recap for those who don't know my truck.
79 F100. Original NC truck. My father bought it in '98 to tow his burnout Volvo (truck matched, was old and was rust free).
Pic from '99 I think, after he changed wheels and added running boards. He paid $4K with a knocking 302 and slipping C4. Truck went through a nice stock 302 (no power), a 351W (I blew that up). Flash forward to 2002. No more Volvo, but the trailer was getting regular use towing other stuff around. I had a 460/c6 from a 78 Lincoln that I talked him into using.
Truck then had a mild 460/C6. Drove great and towed my Cougar around pretty easily. For reasons unrelated to this thread, my father sold the truck in 2003 so he could use a vehicle for work and get paid for it.
I saw the truck for sale in 2006 so I buy it back from the guy. Since that time I've done quite a few things.
Cleaned up the engine bay.
Redid the dash
3"/5" DJM drop. with 17" wheels and tires.
this is the *start* of the thread for my engine. Truck needs an engine bad. Burned oil at rate of 1 qt every 200 miles or so. Trans slipped around turns. I was going to spend the $ on a build, as I had a 60K mile stock 460/C6 from an 86E350 sitting, but then another drivetrain fell into my lap.
As of now..
Engine:
None right now!
Exhaust:
Hedman headers (1 3/4" primaries 3" collector)
3" headpipes
3" Dynomax Super Turbo mufflers
2.5" tailpipes (flowmaster U Fit Kit)
2.5" Dynomax Bullets, used as resonators
Drivetrain:
None right now!
Added OEM optional transmission cooler from an F250
9" upgraded with 31 spline axles
3.25:1 open diff
Suspension:
Larger Thunderbird disc calipers in front
Braided brake lines up front
F350 Power booster and master cylinder (increased stopping power)
Stock springs with 3/4 coil removed in front
DJM 3" Dream Beam front drop
DJM 4" rear drop (shackles and spring mounts)
DJM shocks
Addco 1" front sway bar
17x7" American Racing Ansen Sprint wheels
255 50 17 Falken STX01 tires
Exterior mods:
Clear corners, front and rear
73-75 grill shell swap (round headlights)
Sport style rear bumper
Hard bed cover
Trailer hitch!
FORD 3rd brake light cover for trailer hitch mount
H4 style headlights with 80/100 watt bulbs
Interior Mods:
White face gauges
Sunpro 3" tach
Added tilt wheel
Hurst Promatic 2 floor shifter
Custom Autosounds radio (fits OEM dash)
Python Alarm
Misc mods:
Dual Headlight relay upgrade
Actually put back the charcoal canister and made it work with the Edelbrock carb.
Added the following as well-
optional dual horn setup
optional under dash lights
optional glove box light
optional hood lock
optional overflow tank
Redid the dash
As of now..
Engine:
None right now!
Exhaust:
3" headpipes
Drivetrain:
None right now!
3.25:1 open diff
Suspension:
DJM shocks
Exterior mods:
Hard bed cover
Trailer hitch!
Interior Mods:
White face gauges
Sunpro 3" tach
Added tilt wheel
Python Alarm
Misc mods:
optional hood lock
Which brings me to today, finally started doing *something* to it. Chrome valve covers never last around here. Went through a new air cleaner lid and valve covers. I was too cheap to buy aluminum valve covers, but I came across these a few years ago. To keep them low maintenance I sprayed with with stainless steel paint, polished the ribs, and clear coated the whole thing.
Still around. I parked the truck two years ago when the 460 AND the C6 both became tired.
Engine: C9VE block -- .040 over and internally balanced with football rods, forged pistons and Total Seal rings.
C9VE heads -- ported on the exhaust side to remove the thermactor bumps ARP studs.
Mild Crane cam, Comp Cams Magnum rockers, Performer intake, Holley 750 w/vacuum secondaries and ARP stainless bolt kit.
MSD 6 box on an OEM Duraspark dizzy. CVR mini starter.
Transmission: C6 with upgraded planetary gears from an E40D. TCI deep aluminum pan.
I can't take credit for the build, as it was in a car I bought, and ran excellent. I am simply regasketing, changing the timing chain, and installing.
on
on
The E4OD planetary set will lower the ratio of 1st and 2nd gear. 3rd gear remains the same at 1:1. So, it is essentially a "wide ratio" gear set, which would allow you to run higher rearend gears and maintain the the same performance off the line. Do some google searching and you will find all of the specifics on the setup.
on
It sucks, when we built the engine (basically a regasket and change the top end) that was in it in 2002, it ran great. A little slow, but towed and was a great daily. father sent out the truck to have the carb tuned. He sold the truck, then I bought it from the owner in 2006...... THAT GUY made a mess. changed the carb, didn't change rods, disconnected the A/C.. Got the truck back and it drank/leaked oil around 1 qt ever 200 miles, and the trans slipped around corners.
Dug out the Edelbrock Performer intake that was on the truck originally. I'll be using it on this engine. Nice and torquey. Yes it's aluminum, and painted.
Also got a new 120gph fuel pump. This engine had an 80gph, but that pump is back in the gray Cougar. I had a stocky 40gph pump in the truck. This pump can be modded with a drill, a tap, and some AN fittings to increase the flow to 172gph. If I need it, I can do it.
Clip off only IMO
Hood hell, whole front clip makes it barely a 2 man job. Never again with out the front clip off, 12 ish bolts + 4 for the hood and some elec connectors.
I have wrestled them things and killed my back for hours starting the trans bolts ect...now just set on the tire and enjoy a eng change.
