really hard starting issue
Old Jun 19, 2011 | 03:41 PM
pjwoolw's Avatar
pjwoolw
Thats about like mine starts warm at the moment. Mine may be actually a little worse. The new IPR o rings will likely take care of it.
Old Jun 19, 2011 | 03:53 PM
Peterbilt376x's Avatar
Peterbilt376x
hopefully! lol now im not sure if it is part of the problem or not but i decided to check my fuel pressure and it was around 45....ive seen than you dont want to be below 50.....should i get a bb and try to shim it?
Old Jun 19, 2011 | 04:39 PM
pjwoolw's Avatar
pjwoolw
45 at idle isn't all that bad IMHO. Closer to 60 is of course better. I've never been a fan of the BB trick. But is a quick band-aid. You could just order the Cali spring kit from Ford.
Check both FPR screens. Yours should have a removable black plastic fella hanging down from the FPR. There is a cleanable screen in there Also the screen to the return line to the tanks. In the fuel bowl at about one o'clock.
Old Jun 21, 2011 | 02:16 PM
Peterbilt376x
well i did the o-rings last night and it solved the hard/ no start issue. but it still lopes likeit does in the first video when i start it.....i think its cool but i know its not right any thoughts as to what can cause that?
Old Jun 21, 2011 | 05:20 PM
oldbird1965's Avatar
oldbird1965
Did you try to see how it runs with the ICP unpluged. Maybe that was mentioned above, I don't remember.
Old Jun 21, 2011 | 08:44 PM
Peterbilt376x
i believe it idles with that lope but ill double check tomorrow
austin.clark2
19
May 18, 2014 05:39 PM
77_F150_4x4
Jan 9, 2013 03:36 PM
joe.d
Aug 14, 2011 06:56 PM
AndeyHall
Nov 11, 2010 10:21 PM
mfg02
Modular V10 (6.8l)
17
Jul 28, 2010 04:43 PM
