Ladder bar brackets are on
Old Jun 18, 2011 | 06:48 PM
wmiller's Avatar
wmiller
Finally got time to mount the front brackets for my ladder bars tonight. Measure 6" wide 9" tall and 2" across using 1/4" steel. Hoping to put tabs on the axle soon and bars made up
Old Jun 18, 2011 | 07:39 PM
ccarrier's Avatar
ccarrier
build me a set!
Old Jun 18, 2011 | 08:41 PM
F350-6's Avatar
F350-6
Looks good. I take it you're building the bars in place or using an adjustable heim joint on them since you're mounting brackets first?
Old Jun 18, 2011 | 09:07 PM
wmiller's Avatar
wmiller
Im going to use top link end from a 3 point hitch so it will be adjustable if need be. I thought about making more
Old Jun 18, 2011 | 10:38 PM
Talyn's Avatar
Talyn
I'm lovin the horns!
Old Jun 19, 2011 | 08:26 PM
dougbrown's Avatar
dougbrown
I'm lost! What are they for?
Old Jun 19, 2011 | 08:31 PM
coreylasalle's Avatar
coreylasalle
im assuming ladder bars are traction bars
Old Jun 19, 2011 | 08:35 PM
dougbrown's Avatar
dougbrown
That what I was thinking but not sure!
Old Jun 20, 2011 | 09:49 PM
wmiller's Avatar
wmiller
They will go between the axle and brackets to help take out the nasty spring wrap and wheel hop
Old Jun 20, 2011 | 09:54 PM
oreocreaming's Avatar
oreocreaming
bracket looks good. you are gonna put a shackle in there right? if not your gonna get a ton of pressure pushing it forward when you compress your suspension and a lot of pull when you extend it. creates a lot of binding.
Old Jun 20, 2011 | 10:00 PM
whack&stack's Avatar
whack&stack
i will be building a set of these also. looks good
Old Jul 30, 2011 | 12:44 PM
wmiller's Avatar
wmiller
No shackel on it but i did make them long (almost 7 1/2') so they should still allow so articulation.
Heres the truck with them on. I'll try to get better pictures later
facusessa
39
Jul 10, 2013 09:34 AM
im2tall33
107
Apr 29, 2012 01:58 PM
Krisx125
Dec 22, 2011 05:41 PM
Jexes23
Jun 18, 2011 11:42 PM
superbean
33
May 6, 2011 02:10 PM
