cluster change problem
Old Jun 17, 2011 | 05:00 PM
noeld's Avatar
noeld
well i found another 96 gauge cluster with a tach for my 96 f150 so i swaped them out today,but the tach dont work dont even wiggle & my fuel gauge dont work when switching tank still reads about 1/4 on both,i dont know how to test the tach or the fuel gauge,so am asking for some help from anybody
thx noel
Old Jun 18, 2011 | 03:05 AM
TexasGuy001's Avatar
TexasGuy001
Are you sure the cluster is out of a 96, and not a 94 or 95?
Old Jun 18, 2011 | 11:27 AM
noeld's Avatar
noeld
no am not 100% sure what year it came out of as i never saw the truck got it from the junk yard
how can i tell ????????
thx noel
Old Jun 18, 2011 | 04:34 PM
noeld's Avatar
noeld
thx noel
am taking back cluster i think they were trying to pull a fast one on me more then likely some guy that thought that all digital clusters were the same
was pretty much confused till a checked the wiring on the pluges that were on the new cluster compaired to the ones in my 96 they were nothing alike not even close
thx noel
Old Jun 21, 2011 | 06:39 AM
TexasGuy001
I'm not sure what part numbers coincide with what years. I do know that since you have a 96, you need a 96 cluster.
The compatible years are 92-93, 94-95, and 96. 94-95 has and air bag so its different than 92-93, and 96 is OBDII so it is also different.
The connectors are positioned slightly different on tach and non tach clusters. I think the are both verticle on non tach and one is horizontal on tach clusters. They still plug in though. It should be a plug and play swap.
Here is a tip. So that you don't have to take it all back apart soon, replace all the 194 bulbs and be carefull not to damage the circuit board on the back.
Old Jun 21, 2011 | 10:19 AM
noeld's Avatar
noeld
from what i understand the 97 f250-f350 will also work & this wire dia shows that the plugs are wired the same for gas & diesel but dont know if the boards are the same i also think the diesel clulster has diesel written by the gas gauge
