Rear Axle-V828A
those numbers dont meen much to most people as you said.. there are basically two axles, the smaller 8.8 and the larger 9.75 inch. Inside you get the 3.55 gears, 3.73, 4.11 or 4.56 gears.. etc.. If you have a crew cab and 5.4 V8 you get the larger 9.75 axle.. Look at the tag on the axle and see if you see the size and ratio.
jrockdiddy
12-22-2015 02:31 PM
Cajunboxer
6.7L Power Stroke Diesel
12-01-2015 11:45 PM
Cajunboxer
08-14-2015 08:12 PM
