Sponsored by: Real Truck
Mag Lite Mount
Old Jun 17, 2011 | 08:32 AM
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
Old Jun 17, 2011 | 08:47 AM
Eatonpcat's Avatar
Eatonpcat
6D Bigger is always better...Unless of course your talking about the ladies!!!
Old Jun 17, 2011 | 09:07 AM
sddesigns's Avatar
sddesigns
FTE Emeritus
I know a smaller light is useful too in certain situations, which is why I have a little pocket sized LED in my tool box!
Old Jun 17, 2011 | 10:33 AM
lakedweller's Avatar
lakedweller
Only question I have is why a 6 cell Mag Lite? I have a 2 cell and it is all the light I need. If you are using it for protection instead of a baseball bat, I will do you one better just put a 357 Mag in the side pocket....
Old Jun 17, 2011 | 10:49 AM
sddesigns's Avatar
sddesigns
FTE Emeritus
Not in New Jersey my friend!
Old Jun 17, 2011 | 11:10 AM
jc8825's Avatar
jc8825
Is the LED really better than the bulb? I have used LED flashlights, and they seem to produce less USABLE light.
Old Jun 17, 2011 | 11:14 AM
sddesigns's Avatar
sddesigns
FTE Emeritus
They are freaking bright, the light pattern doesn't have the same distance as the incandescent bulb, but it's near daylight.
Old Jun 17, 2011 | 11:42 AM
northwindone's Avatar
northwindone
The LED used in a Maglite is not your standard LED and are extremely bright compared to the standard Krypton bulb Maglite. However, the problem I have with both my 4 cell, and occasionally my mini LED Maglite, is that they like to flicker on and off a lot even though they are brand new and have no corrosion on the battery spring. In fact, my first 3 Cell LED actually died after 2 weeks of use and I've been procrastinating sending it back to Maglite for warranty repair. Part of me wishes I had just replaced my old standard Maglite with another standard one even though the LED ones are much brighter and have better battery life. By the way, never leave your Maglite sitting around long enough for the batteries to leak; I've lost two Maglites now that way since the batteries will NOT come out once they have swelled up.
After having my Maglite floating all over the truck on my last camping trip though, I think I'm going to buy some of these clips.
Old Jun 17, 2011 | 12:24 PM
sddesigns's Avatar
sddesigns
FTE Emeritus
Originally Posted by northwindone
The LED used in a Maglite is not your standard LED and are extremely bright compared to the standary Krypton bulb Maglite. However, the problem I have with both my 4 cell, and occasionally my mini LED Maglite, is that they like to flicker on and off a lot even though they are brand new and have no corrosion on the battery spring. In fact, my first 3 Cell LED actually died after 2 weeks of use and I've been procrastinating sending it back to Maglite for warranty repair. Part of me wishes I had just replaced my old standard Maglite with another standard one even though the LED ones are much brighter and have better battery life. By the way, never leave your Maglite sitting around long enough for the batteries to leak; I've lost two Maglites now that way since the batteries will NOT come out once they have swelled up.
I sent my last 6 cell back to Duracell after they leaked and they sent me a full retail check for a new 6 cell with a coupon for replacement batteries and enough over the actual price to buy the LED option.
Old Jun 17, 2011 | 12:49 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
If you buy the LED maglite (Not a regular mag lite and add an LED) it is WAY brighter than an incandescent, however it still comes with an incandescent spare bulb.
Old Jun 17, 2011 | 08:54 PM
robert_l_ross's Avatar
robert_l_ross
Put mine in today...the seat belt retractor 'hump' is barely tall enough to hold both mounts in a 2000 Excursion:
Old Jun 18, 2011 | 07:18 AM
sddesigns's Avatar
sddesigns
FTE Emeritus
Looks great, a lot smaller than the 2001.
Old Jun 22, 2011 | 09:16 PM
  #28
marz's Avatar
marz
Originally Posted by sddesigns
I used all stainless and washers with lock nuts.
I have these maglite mounts and am ready to install but I am weary of using the screws provided and just tapping them into the plastic... is that what you guys did? Does it hold well over time?
I have had my 06 F250 for under a month and I don't want to do anything I will regret (i.e. having 4 hogged out / stripped holes in the seat belt hump).
Old Jun 22, 2011 | 09:28 PM
  #29
add2255's Avatar
add2255
Use small round head bolts with washers and lock nuts and don't jerk the light out it should be good
Old Jun 22, 2011 | 09:30 PM
  #30
robert_l_ross
I haven't had mine in long, but I pull mine up to remove it, so that might limit the chance of pulling it out and stripping it.
