Is that a date and odometer reading in red labelmaker?
Don't know what that is.
If I didn't have the box of receipts that I have, I'd lean towards that conclusion myself.
However, my box-O-receipts puts the mileage on the truck at around 35K in 1983.
It seems to me that the label maker number has the zero sort of seperating the 69 and the 98. I guess I need to dig more in the receipts from June of 1983 and find out why it would've had a red labelmaker tag put on it like that.
F10 = F100 4X2
A = 240 cid inline six
K = Kansas City assembly plant
732803 = August 65 build (very early)
115 = wheelbase
HM = Tutone paint, white over beige
F100 = 5,000 GVW
M81 = Medium beige crush vinyl and medium beige woven plastic, standard cab 81A
C = 3-speed manual trans
09 = Ford 9-inch 3.70 ratio
65 = Oklahoma City ordering district
ND, did jhooch have the right info? just wanna know
HM: H = Sahara Beige / M = Wimbledon White (there was also C = Pure White).
C = Ford type 3.03 3 speed manual all syncromesh trans.
The 09 Warranty Plate Axle code decodes to: without Limited Slip // 1959 thru today: If the axle code begins w/a letter: Limited Slip / If with a number, no Limited Slip.
Omitted: GVW = 5,000 lbs. Gross Vehicle Weight Rating / 172 net HP @ 4,000 RPM
I have a 1965 F100 it came with a 351c in it trying to find out what transmission is in the truck.
Tag has RAN BY2 GA 022403 Also on the driver side the case has D2 AR 7008 AB Any help would be greatly appreciated.
Hey, welcome to FTE. You really ought to make a new post . This one is nine years old. And add photos if you can. I can tell you though that any numbers you find are probably not part numbers, but rather casting numbers, and are not really all that useful, but someone can steer you in the right direction to figure things out.
