Front tank issues
Old Jun 15, 2011 | 08:02 PM
jeworthington's Avatar
jeworthington
Front tank issues
I have tried to search for this answer but.....don't quite get what I think I need. So here goes: 1997 F250 7.3 PS. Front tank acts full at the pump. Tried moving nozzle in and out slow and fast. Ran for about 30 miles then started sputtering switched to rear and all is good. Can here switch when moved. Front tank sending unit does not work shows e all the time. Is there a vent tube possibly clogged so I can't add fuel or what? Has been running this way for about 2000 miles. Not a daily driver. Tanks have been cleaned and filters replaced within 2500 miles. I have had the truck about a year and have had plenty of fun with various issues Any help is appreciated.
Old Jun 16, 2011 | 01:55 PM
Brians97F250Crew's Avatar
Brians97F250Crew
There is a vent tube but it's just to relieve the pressure built from fuel sloshing, and vapors, ect. Sounds like the tank is full from what you're saying. If you're sure the selector valve is working. I would suggest taking the bed off instead of trying to lower a full fuel tank. Take the sending unit out and inspect it and the tank. There is a rubber screen on the bottom of the pickup. It looks like and upside down funnel and is notorious for breaking off or apart. You may have a piece of it stuck over your pickup tube. While you're there check the ground for the sender it's on the top of the frame by the tank. Good luck.
Old Jun 16, 2011 | 02:37 PM
DIYMechanic's Avatar
DIYMechanic
The other option is that the tank is actually empty, your sending gauge is working and your rollover valve in your fill neck is not allowing you to fill the tank. Could you try siphoning off some fuel to see if there is anything in the tank?
Old Jun 16, 2011 | 04:00 PM
jeworthington
Thanks for the replies. I will try to take a look this weekend but... my son's Chevy now wants to act up Guess that's what happens when you own old trucks?
Old Jun 17, 2011 | 06:10 AM
DIYMechanic
Yeah, but at least these old truck can still be worked on by guys like us.
Old Jun 17, 2011 | 08:37 AM
Talyn's Avatar
Talyn
Yeah, and dont need 4k in special tools just to replace simple things like heater cores.
Old Jun 17, 2011 | 08:55 AM
DIYMechanic
Amen, and you can't beat these engines for durability and fuel mileage and with the right upgrades, these engines can run with the best of them.
Old Jun 17, 2011 | 08:56 AM
Talyn's Avatar
Talyn
you can damn near tear down the motor with a basic sock and wrench set.
Old Jun 17, 2011 | 09:16 AM
DIYMechanic
Yeah there aren't too terribly many specialty tool required. The injector cup tool set is one I can think of, but yeah. Not too bad to work on at all.
Old Jul 9, 2011 | 07:36 PM
bigjim31's Avatar
bigjim31
front tank sending unit
my front tank shows full with only half a tank of fuel and it seems to go down fast when getting close to empty. are the senders hard to change?
Old Jul 9, 2011 | 11:10 PM
oldbird1965's Avatar
oldbird1965
Maybe you just need to do the vent mod. That darn little hose down the middle of the fill tube is insane. Its probably kinked or something is blocking it. With the vent mod I can now fill up where the 'big' trucks do, lol.
Old Jul 10, 2011 | 07:29 AM
Copedawg's Avatar
Copedawg
Could the pick up ttube be blocked? I would wait for it to act up then pull over and open the fuel filler cap and lsten for the sucking sound and see if it straightens back out.
ALSO, the best part of having old trucks is NOT having truck payments
Old Jul 10, 2011 | 10:45 PM
bigjim31's Avatar
bigjim31
tank fill issues
thanks for the info. and yes not having a truck payment is awesome.(IE more money for upgrades)
Phobia16V
36
Jan 18, 2021 04:01 PM
jonnyp617
Jul 6, 2013 01:18 PM
joshofalltrades
18
Jan 20, 2013 07:56 AM
Grey86r
17
Sep 2, 2011 07:11 PM
yellott
Jul 5, 2007 08:53 PM
