EGR valve opening not detected
94 Explorer is throwing code 332, "EGR valve opening not detected." Did the following checks:
- Applied vacuum to the valve. Heard it click. Waited 60 secs, released the vacuum, and it clicked again. So, the diaphragm is not leaking.
- Ohm-checked the regulator. It was within specs.
- Removed valve, thoroughly cleaned mating surface, looked for obstructions inside. (There were none.) Re-installed with new gasket.
Al_Cuevas
1997 - 2003 F150
93
08-13-2016 08:50 AM
78_79ford
09-07-2015 05:48 PM
flare-f150
1997 - 2003 F150
07-20-2015 06:42 PM
fastbmw01
19
07-29-2011 12:36 AM
