Power lock issue
Old Jun 14, 2011 | 08:54 PM
sbcstang's Avatar
sbcstang
Power lock issue
I've searched the forum and can't find what I'm looking for. My locks on my 1997 Expy stopped working. I get nothing in lock or unlock from both door switches.
Ive checked fuse 3 under the hood and it's good. Also checked all RAP labeled fuses in the pass compartment. All of those are good also. At the drivers side switch I have no power on any of the wires. I cannot find the 3 power lock relays that I've read about. I have the kick panel removed.
Can anyone please help? TIA
Old Jun 14, 2011 | 09:35 PM
pdqford's Avatar
pdqford
Lock relays should be behind the right side of the I/P.
I wouldn't think they all let go at the same time.
Old Jun 14, 2011 | 10:24 PM
High_Horse's Avatar
High_Horse
Make sure your umbillical is plugged in tight under the dash by the steering column, the big one with all the wires. Seems hard to believe it could come loose, but I've had some strange things happen on vehicles.
I'm more than likely to believe its what pdqford said though...
Old Jun 15, 2011 | 03:19 AM
alloro's Avatar
alloro
Here's a PDF of the power door lock wiring diagram if it helps.
File Type: pdf
Old Jun 15, 2011 | 08:24 AM
sbcstang's Avatar
sbcstang
Thanks alloro. I've got that same schematic in my Haynes book. Now that I look at it closer I wouldn't have power at the switch. Looks like the switches just complete a path to ground to tell the RAP module which relay to activate.
I looked all over under the dash and cannot find the relays. I found 1 block that has 2 in it attached to a bracket that the brake controller plug also is connected to but the wires don't look to be the correct color. Does anyone have a picture of where to find these replays?
Also is it possible that the RAP has gone bad?
Old Jun 15, 2011 | 09:20 AM
alloro's Avatar
alloro
On the top of the dash, there's a large panel that pries up and comes out. I'm fairly certain the relays are under there.
Old Jun 15, 2011 | 10:40 AM
sbcstang's Avatar
sbcstang
Isn't that where the 4x4 relays are? I have that panel off and can't see any group of 3. ugh.
Old Jun 15, 2011 | 08:38 PM
sbcstang's Avatar
sbcstang
Alright. So I found the relay bank. Holy cow is it buried. I probed the Black/White stripe wire and do not have power. Does anyone know where the wire splits for the 3 relay inputs? I checked the main connector at the firewall and it seemed tight. That is the one with the handle right? Is there maybe another connector that is between the relay bank and the power distribution block other than the firewall connector? Sorry for all of the questions but I would like to be able to lock my truck and I can't believe I can't figure this out. I usually am real good at electrical work. Thanks!
Old Jun 15, 2011 | 10:03 PM
pdqford's Avatar
pdqford
I know you said that you tested fuse #3 in the PDB (Power Distribution Box) under the hood. But with the fuse removed, does one of the recepticles have battery voltage?
If no voltage there, you may have to pull the PDB and check the bottom side of it for "green' (trademark) crud preventing contact with the buss.
Old Jun 16, 2011 | 08:02 AM
sbcstang's Avatar
sbcstang
Yes I did. I have voltage on the inside spade with the fuse removed. I guess I'm going to be removing the box to check the underside. Thanks for the help. I should have thought of that myself. Just because the fuse is showing power across both sides doesn't mean that the power is getting past the fuse.
ryankerr
Electrical Systems/Wiring
Mar 5, 2014 10:06 AM
Gannbino
Oct 6, 2012 09:57 PM
rt 77
Escape & Escape Hybrid
Feb 23, 2011 11:01 AM
JTD1972
Jun 1, 2006 12:38 PM
