6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
looking at a 6.4
Old Jun 14, 2011 | 08:01 PM
thefordlane's Avatar
thefordlane
looking at a 6.4
Hey guys im looking at a 2008 f350 with a 6.4 with 33,000 on it. Im just wondering if there is anything i should look out for i.e. injector problems turbo problems and so on. Ony advice would be very helpful.
Thanks
Lane
Old Jun 14, 2011 | 08:15 PM
senix's Avatar
senix
check the hours on this motor. If it has an average of about 35 mph then that is good. Probably means more hwy time.
Look at the radiator and along the frame down by the radiator for leaks. That is a weak point.
Other issue is the DPF. You want to check the tail pipes. Clean to grayish as most means that that is working good.
Maintance records..and OEM fuel and oil filters. Can it be proved.
dannyadames44
Mar 14, 2023 08:45 PM
AHermann06
24
Oct 18, 2016 10:34 PM
jessejoeroge
Oct 3, 2015 02:00 PM
tracyclifton
Jun 17, 2015 06:04 AM
BigMitch64
Mar 8, 2015 07:14 AM
