gas
Old Jun 14, 2011 | 07:54 PM
White Boy's Avatar
White Boy
gas
just bought a 1978 ford f150 v8 6.6 liter engine..old owner ran 93 gas in it..is it ok to run 87 in it now
Old Jun 14, 2011 | 08:14 PM
fmc400's Avatar
fmc400
MSEE
If it's the stock engine (stock compression), there's no reason to run anything but regular in it.
Old Jun 14, 2011 | 11:39 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
Like the guy above said. 87 is where its at for the motor, and it will likely runa bit better on 87 vs 93.
Old Jun 15, 2011 | 02:37 AM
Deadkid9110's Avatar
Deadkid9110
It depends. If you're going for speed, keep on 93 Octane. It'll keep your wallet empty; less weight on your pickup!
Nah, use 87 octane. I usually run 87 in my pickups, and it does just fine.
Old Jun 15, 2011 | 05:07 AM
White Boy's Avatar
White Boy
Its a rebuilt motor. And he said he always ran 93. So u guys are saying 87 is fine to run. Won't harm engine
Old Jun 15, 2011 | 06:33 AM
Burburan's Avatar
Burburan
The only difference between 93 & 87 octane is the detergents that are added at the gas station. That being said, the tanker truck that fill up the stations only carry regular gas and the attendants are suposed to put in the detergents in the 89 and 91 or 93 to change the octane. Is it done, probubly not always, so don't worry obout it.
Old Jun 15, 2011 | 06:59 AM
White Boy's Avatar
White Boy
Ok thanks everyone
Old Jun 15, 2011 | 07:18 AM
KrautBurner's Avatar
KrautBurner
As long as the previous owner didn't advance the timing for 93 only.
The only way to actually get performance out of higher octane is if you advance the timing for it, but it will detonate on regular gas.
Put regular in her,
If she starts to ping under light load, adjust the timing.
Old Jun 15, 2011 | 07:22 AM
KrautBurner
Not true.
The fuel comes to the stations in different tanks (of diffeent octane)
The additives are not what change the octane
Octane is important to some engines.
It's the fuels resistance to detonation.
Old Jun 15, 2011 | 07:28 AM
KrautBurner
Good info on Octane rating
Old Jun 15, 2011 | 08:11 AM
Justin's Green Truck's Avatar
My stock 77 runs much quieter when I put 93 octane in it compared to 87. I always assumed it was because with the absence of lead in fuel now, it needed higher octane to compensate. Maybe this is totally wrong, but there is a noticable difference in engine noise and how smooth it runs.
Is it OK to run 87 in it? Sure id say it is... Ive ran mine with 87 and it does just fine, its just louder for what ever reason
Old Jun 15, 2011 | 09:15 AM
KrautBurner
what do you mean by louder/quieter?
is it "Ping/Knock"?
if so, you should be able to adjust the timing a bit (if this dosn't help, you may "Need" to run higher octane, but that's a seperate problem)
sometimes, you get so much buildup of carbon on the pistons that it can raise the compression of of the engine, causingthis.
I'm not sure, but I believe that your truck (1977) was never intended to run leaded gasoline
I believe all us vehicles were designed to use unleaded gas by 1975
Old Jun 15, 2011 | 11:36 AM
jjski78's Avatar
jjski78
You couldn't be more wrong. If that was the case a VW 1.8T would run beautifully on 87, but I know for a fact that 87 will cause those engines to knock and ping themselves to death because of pre-ignition problems with the fuel. Octane is a measure of the fuel's resistance to detonation.
The detergent packages used by different gas stations are added at the distribution center, not at the station.
Old Jun 15, 2011 | 12:31 PM
dkf's Avatar
dkf
Depending where you live the higher octane fuels usually have less ethanol content. Ethanol can cause detonation issues among many other issues. I try to avoid gas with ethanol in it especially if you store your truck over the winter or something. Luckily I can still get pure gas in my area.
If your running 93 now wait until the tank is around half full and refill with 87. If no detonation fill with 87 again when the tanks at around half full and listen for detonation.
Old Jun 15, 2011 | 02:16 PM
White Boy's Avatar
White Boy
Not to be stupid but what's detonation
