Hello. Tonight I took apart my 4.9 to do lifters. Everything went smooth, Until it was time to start it up and now I have no spark. I have power at the coil, I have run, start, and ground at the distributor. I checked both sides of every fusible link I could find. I checked the compression just to make sure they didn't give me the wrong push rods or something stupid and it has 135 pounds so it's not that. It gets fuel so I am stumped. Any help would greatly be appreciated. Thanks
Check all the wiring around the TFI module, for possible damage. Did you unplug the module or remove the distributor when doing the work? Remove the plug wires etc? If so check the firing order and make sure the wires are hooked up correctly.
I only took the plug wires off the plugs. I didn't pull the cap or anything. I wiggled and pulled on everything and it didn't make a difference. I looked for ground wires that I thought maybe I left off but everything looks good.
I tried that and also a spark tester - no spark at the distributor or coil. I am thinking maybe a wire in the harness that runs along the valve cover but I can't find anything obvious.
The easiest for me to find wiring faults is to remove the harness and move it to my bench if it's small. The TFI-IV wiring harness is small enough to do this. Unplug it from the distributor and ignition module, then unplug it from the main harness. First I'd check continuity of all the wires in the harness. With a Ohm meter + lead on one side of the circut or wire, and the negative side on the other side, and if one fails, I unwrap the black protective layer and fix it, then rewrap it with black electrical tape.
Some places can test TFI-IV ignition modules. Just to eliminate it from the possibilities, I would have it tested if I could.
I went on ALLDATAdiy.com :: Leading Source of Diagnostic and Repair Information and paid the $28 one year subscription fee for My Year and model. I found all the wiring diagrams and printed them out and then pulled the connector from the EEC-IV and all the other ends from the sensors and so forth. I pulled all the loom off of the harness and started tracing the wires from one end to the other as per the diagram and tested for continuity. I found the loose junction of 5 wires connected together and reconnected them and it fired right up. What a difference the new lifters made. Thanks for all the suggestions.
