Suspension Issues and questions
Old Jun 14, 2011 | 05:31 PM
bayous's Avatar
bayous
I have an 2004 Excursion Diesel 6.0L 4X4 185K miles
(Is there a place i can put my truck and info so i don't have to type it all the time)
What shots should I get so when i stop the truck doesn't bounce , for a lack of a better word, back and forth. I am looking for something that will give me a more solid ride but yet that its not a rock. Example, When i go over a speed bump it feels like bottoms out.. wasn't happening before but shocks probably wore out. I am not looking for stock ones. I would like after market ones...
Do i need to change springs???
I normally don't tow anything.
Lastly, does the 4x4 version of these truck have to be so high??
Any Ideas
Old Jun 14, 2011 | 06:45 PM
robs97z28's Avatar
robs97z28
I would put adjustable ranchos in the 9000. by turning a **** on each shock you can tailor the ride comfort. if that isn't good enough, you will have to go with v/b coded leaf springs front and back. You can also try using roadmaster overloads in the rear.
Old Jun 14, 2011 | 07:10 PM
bayous's Avatar
bayous
RS9000XL SERIES SHOCK Stock Front RS999267 2
Is what I found.
What about height adjust meant. I would like to have it like gas version or 2x4. You guy probably know what I mean
Old Jun 14, 2011 | 07:15 PM
LivingLarge's Avatar
LivingLarge
Any Ideas
Yes, i believe when you get to 25 post you can add a signature line.
I also agree, Rancho 9000 xl's would be a good start, but with that many miles you probably should re-do your springs. This will raise the truck a couple inches and from your last statement I don't know if you would like that. The positive side is much better ride and handling.
Old Jun 15, 2011 | 02:05 PM
airjeff's Avatar
airjeff
Shocks will help, but you are probably bottoming out and need new springs too.
Billy Bob Jo
Car/truck Buying Advice
Mar 25, 2012 06:47 PM
2003 f-250
Aug 17, 2011 02:09 PM
sammydiesel
13
Dec 10, 2009 04:42 PM
'94Nichols
1997 - 2003 F150
21
Jun 11, 2008 01:20 AM
vwpartsman
Modular V10 (6.8l)
Jul 25, 2007 04:54 PM
