just a quick question
Old Jun 14, 2011 | 01:02 PM
thebig350's Avatar
thebig350
Hey guys just wanted to know if the badges on the fenders are bolted through or just glued?
Old Jun 14, 2011 | 02:58 PM
pjwoolw's Avatar
pjwoolw
Its kinda a double stick tape on the back of the badges.
Old Jun 14, 2011 | 09:55 PM
thebig350's Avatar
thebig350
Okay thanks Pete. Anybody have any tips on how to get them off
Old Jun 14, 2011 | 10:02 PM
clean '97's Avatar
clean '97
heat gun
i would use a heat gun to soften the adhesive first,then pull the badge away.
razor blades also work but you have to be really carefull not to scratch the paint
Old Jun 14, 2011 | 10:04 PM
fordpride's Avatar
fordpride
10lbs test fishing line and a blow dyer you the blow dryer to heat it up and use the fishing line behind it in a sawing motion to cut the tape
Old Jun 14, 2011 | 10:06 PM
fordpride's Avatar
fordpride
after you get it off you can get a body eraser from O'reilly to get the leftover tape off
Old Jun 14, 2011 | 10:09 PM
thebig350's Avatar
thebig350
Genius thanks mike, john.
Old Jun 14, 2011 | 10:13 PM
fordpride's Avatar
fordpride
it's got a couple dial pins behind it you have to work around
Old Jun 14, 2011 | 11:49 PM
Brown Falcon's Avatar
Brown Falcon
Yep, heat it up and carefully remove. And there are 2 pins that go through into the fender just to line it up right.
rfw0002
New Member Introductions
Sep 29, 2007 12:13 AM
pumpkinbronc
Mar 15, 2006 05:41 AM
yves
Aug 24, 2005 03:56 PM
rikfish
Nov 22, 2002 03:06 PM
MartyB
May 17, 2002 07:27 PM
