Rough Start in The Mornings
Old Jun 14, 2011 | 04:13 PM
bayous's Avatar
bayous
Originally Posted by 2006lariat
I am with Mark. You need too have your Fuel Injector Control Module (FICM) tested. You shouldnt even need Glowplugs in "Africa"! Maybe have your HPOP checked out too, as it sounds like your injectors are not firing right (stiction).
Thanks guys.. this place i linked in previous post will check this out also.. I let you know tomorrow
Old Jun 15, 2011 | 07:45 PM
bayous's Avatar
bayous
Rev-X is in the truck. Let's see what happens.
Old Jun 15, 2011 | 08:09 PM
2006lariat's Avatar
2006lariat
I meant have your high pressure oil system checked, not your pump (HPOP). I am sorry!
Old Jun 15, 2011 | 09:39 PM
bayous's Avatar
bayous
What would be a correct pressure?? I have a diagnostic computer that gives me all those details
Old Jun 15, 2011 | 10:00 PM
jandlstables's Avatar
jandlstables
I had the same issue with my truck. Would not start inmorning unless it was plugged in. Once it was started it was anemic until it warmed up. It only was getting down to the low 50's at night. Replaced FICM with a rebuilt one that was bumped up from 48 volts to 58 volts and truck started right up and ran like a bat out of hell. Ran itall winter and never had a problem with it. Even if it got below 20 degrees at night, i did not have to plug it in.
Old Jun 15, 2011 | 10:12 PM
bayous's Avatar
bayous
Where can I get one. Just in case. And is there a diagram as to where it's located.
Old Jun 15, 2011 | 10:38 PM
jandlstables
Custom FICM Reprogramming
Kinda pricey but really did a number on my truck.
Old Jun 15, 2011 | 11:07 PM
BLADE35's Avatar
BLADE35
Originally Posted by bayous
My First Post
I have a 2004 6.0L Excursion 4x4 which I bought Used.
Every Morning when I start My truck. I have to wait for itto warm before i can use it.. I have no power when leaving my house. i can floor it and the just moves slowly and it struggles.. but once it warms up in a bout 10 min the cars run normally through out the day.
help
I think your power loss is way to severe for hot shot secret/rev x to work
Im with bismic trouble shoot tech folder lots of things can cause this
Old Jun 16, 2011 | 10:50 AM
bayous's Avatar
bayous
where would i be able to get a FICM if i need one
Old Jun 16, 2011 | 03:16 PM
2006lariat's Avatar
2006lariat
Look at Swamp's Diesel, I put on of their's on my truck. Lots of other places sell/rebuild them. Use search function, ppl have had lots of luck with others. Make sure your batteries are good. Have you had your hpos pressure checked? Nosense in throwing $350-$1,000 in parts at it if it wont fix it! Have You checked your FICM volts? It was designed too be at 48volts? Check the tech section for procedures. It can be very expensive throwing parts at your truck too "see" if it gets fixed! You really should have it all checked out, if you feel you cant do it. (Sorry if that offended you, but I think in your case it should have a couple checks done by a FORD Diesel Mechanic) It would prob save you some money in the long run. Scangauges can monitor FICM volts, I think!
Old Jun 16, 2011 | 07:01 PM
BLADE35's Avatar
BLADE35
SGII will monitor
fivm mp48volt
ficm lp 12volt
ficm vp 12volt
ICP,IPR,EOT,ECT,BOOST,BATTERY,GEAR,TRANNY RANGE,EGR,MAP.EBP and a bunch more
160.00 for the SGII well worth it mines paid for itself quit a few times over
TRY THIS
www.scangauge.com
click here^^^^^^^^^^^^^
Old Jun 16, 2011 | 07:35 PM
2000 roadking's Avatar
2000 roadking
how would your ficm cause it to run bad when cold but run great after warm up? my 03as done this since 84,000 And I have tried everthing you can pour in one. cheezit said in here one time that was bad injector or injectors or ones fixing to bad.
Old Jun 16, 2011 | 07:40 PM
  #28
BLADE35's Avatar
BLADE35
the solder joints crack in the ficm and dont get good contact when cold but when it warms up everything expands and your ficm voltage comes back and truck runs better
other things also can cause rough run when cold
its just one thing to check
also does your oil smell like diesel watch it close to see if your making oil
my injector o-rings used to leak fuel untill it got warm and they sealed up it ran bad missing cylinders wouldnt shift right and so on
Old Jun 16, 2011 | 07:42 PM
  #29
npccpartsman's Avatar
npccpartsman
If the FICM voltage is dropping out the injectors won't fire correctly. It should be 45+ volts ALWAYS, even when cranking. 48v is actually the correct voltage.
To the OP: FICM Repair.com - Your Source for FICM Repair does great work at reasonable prices. Check him out.
Old Jun 17, 2011 | 10:14 AM
  #30
F250BlackChrome's Avatar
F250BlackChrome
Originally Posted by BLADE35
SGII will monitor
fivm mp48volt
ficm lp 12volt
ficm vp 12volt
TRY THIS
www.scangauge.com
Where did you get the "codes" for FIVM, FICM lp, Ficm vp ?
and what does fivm mp, ficm lp, and ficm vp stand for?
I know Fuel Injection Control Module.
