HELP! What is another name for the Fuel Filter Restriction Sensor
Old 06-06-2010, 07:27 PM
TimmyAbrams's Avatar
TimmyAbrams
TimmyAbrams is offline
1997 F-250 PSD
I found my fuel filter restriction sensor leaking this evening! Is there another name for that part so that I can find it at advance auto, autozone, or napa? I have those stores local, but the dealership here does not carry parts. The leak is about a drop every two to three seconds, so it's a decent leak.
I gotta drive the truck like that tomorrow, and I'll fix it in the evening!
Thanks auto gawds!
Tim
Old 06-06-2010, 08:22 PM
Talyn's Avatar
Talyn
Talyn is offline
Fuel filter restriction sensor.................................
Can i get a picture? haha.
I don't know of any sensors like that.
are you sure your not talking about the water in fuel sensor?
Old 06-06-2010, 08:55 PM
Hussler's Avatar
Hussler
Hussler is offline
Fuel filter vacuum switch, top sensor.
Old 06-06-2010, 09:33 PM
Talyn's Avatar
Talyn
Talyn is offline
I must not have one of those?
Old 06-07-2010, 12:15 AM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
1/8" NPT plug from the hardware store will fix it also. Careful on the R & R in any case. The FPR (the thing the sensor is attached to) is pretty fragile. Could crack if you over tighten the plug or sensor.
Old 06-07-2010, 07:28 AM
Talyn's Avatar
Talyn
Talyn is offline
picture anyone?
Old 06-07-2010, 10:00 AM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
Here you go.
Old 06-07-2010, 06:54 PM
TimmyAbrams
Thanks guys, I cannot justify spending the $70 from a stealership for the part and shipping. Today, I installed a 3/8" brass pipe pung/end cap into the space. I dont remember the thread pitch, but it was either 18 or 20 tpi. The pipe bung was a whopping 37 cents. I might put the right part in eventually, but probably not. I'm a cheap azz.
(not so)advance auto, autostoned, and crapa could not get me a new sensor, no matter what i called it. Such is life.
Thanks all!
Old 06-07-2010, 10:43 PM
Talyn's Avatar
Talyn
Talyn is offline
oh, my 94 doesn't have that. =)
Old 06-08-2010, 03:10 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Wink
Yes it has, but its located in the bottom of the rear part of the cannister, look here
Talyn's Avatar
Talyn
Talyn is offline
I dont have it. =)
Old 06-08-2010, 03:15 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
I dont have it. =)
Uhhhh? did you see the schematic?, if there is not the switch, surely somebody put there the 1/8 NPT plug before.
Old 06-13-2011, 12:18 AM
Trader_Dick's Avatar
Trader_Dick
Trader_Dick is offline
Fuel Filter Vacuum / Restriction Sensor
Seriously? I can just plug the hole and move on with my life?
What are the downsides of just plugging the hole and moving on, instead of buying and installing a new fuel filter vacuum switch or fuel filter restriction sensor, or whatever it's called?
Thanks,
Dick
Old 06-13-2011, 12:22 AM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
Yep. Just keep up on your fuel filter changes and keep the return screen in the bowl clean. Don't tighten the plug to tight. Could crack the FPR.
Old 06-13-2011, 01:19 AM
Trader_Dick
Thanks
OK, 1/8th inch 18 or 20 threads per inch, right?
Anything special as a washer when I plug this? What length should I use? The thing is dripping 1 per second now, and I'd like to get 18 MPG on my 1996 f-250 power-stroke that has 291,000 miles, instead of the 16.5 I'm getting now. Of course, when I change the gears from 4:10 that may help, as will adding a Banks programer... anyone have any other ideas?
Thanks,
Dick
Quick Reply: HELP! What is another name for the Fuel Filter Restriction Sensor
