FTE Electrical Wizards Please Help!
Old Jun 13, 2011 | 08:47 PM
I fish's Avatar
I fish
Originally Posted by alloro
The only difference when you step on the brake versus using the hazards or turn signals is that power is sent up to the third brake light only when pressing the brake pedal.
doesn't it also tie into cruise control switch?
Old Jun 13, 2011 | 08:58 PM
78ecf250cs's Avatar
78ecf250cs
The quickest way to find out if it is the third brake light is to unplug it and press the brake pedal and see if it pops the fuse or not
Old Jun 13, 2011 | 09:05 PM
78ecf250cs's Avatar
78ecf250cs
It is pretty much a process of elimination. You already know it has to do with the brake light circuit. My advice is to disconnect 1 item at a time and check to see if it pops the fuse while that item is disconnected then reconnect the item and go to another item in the circuit if all the items checkout and it still pops fuses the culprit is the brake switch.
Old Jun 13, 2011 | 09:25 PM
Smitty1019's Avatar
Smitty1019
Okay, so I've done a little more diagnosing. I disconnected all the lamps on the brake circuit, L & R and 3rd... and the fuse still pops. So I know those are okay. Brake light switch on the pedal the likely culprit?
Smitty
Old Jun 13, 2011 | 09:37 PM
I fish's Avatar
I fish
Still could be related to hazard switch, cruise control switch, trailer harness etc... I'd push back on the dealer to honor the warranty at this point
Old Jun 13, 2011 | 09:55 PM
78ecf250cs's Avatar
78ecf250cs
Where you able to get the remote start system disconnected from the brake circuit? Because at this point its either that or the switch from what you are telling us. And switches do fail.
Old Jun 14, 2011 | 08:13 AM
alloro's Avatar
alloro
FYI, the switched wire off the brake switch runs up the steering column and to the multifunction switch. So there could also be a chaffed wire in there or the MF switch could be internally shorting.
Old Jun 14, 2011 | 10:59 AM
Smitty1019's Avatar
Smitty1019
Okay, so the plot has thickened. I did locate and disconnect the remote start system and replace the #2 fuse yet again. And lo and behold when I depressed the brake pedal, the fuse did not pop! I reconnected the remote start and depressed the brake again and still the fuse has not popped. So that makes me scratch my head some... I did notice some bare not connected wires coming out of the wiring harness for the remote start module which also was curious. I assume they were not needed for my application, but to leave them bare and exposed points me towards a shoddy install.
Thoughts?
Thanks again guys!
Smitty
Old Jun 14, 2011 | 11:49 AM
I fish's Avatar
I fish
because it was put on by the dealer, Your remote start unit might have options and features that don't apply to your vehicle, although they still should have been at least cut clean and taped or had a butt connecter crimped on to make sure they didn't cause a short
tape up the bare wires and call it done until another fuse blows.
Old Jun 15, 2011 | 07:39 AM
Smitty1019's Avatar
Smitty1019
Update... After taping off all the exposed wires from the remote start harness the fuse has been holding. So hopefully this is resolved.
Thanks for all your help guys!
Smitty
blind180
Nov 14, 2016 10:34 PM
mnkeeking
Nov 25, 2012 05:33 AM
JPdiesel
Electrical Systems/Wiring
Sep 15, 2011 11:06 PM
JPdiesel
Sep 15, 2011 10:11 AM
JPdiesel
Sep 14, 2011 07:01 AM
