Hi Guys, Can anyone tell me what crank pulleys will work on a 400 4 bolt balancer...Mine is bent and I need to replace it. Im hoping its easier to find if I know which ones are compatible.........Thanks
I checked and no number on mine. Take some measurements, this one is a 3V pully for 4bolt balancer, third pully rather large for AC I believe. If you have a number on yours, NumberDummy can help for sure.
inre to the outer pulley: How many sheaves (pulley grooves) do you need, one, two, three or four?
If four sheave, there are 4 different types. Look on your pulley for a stamped ID engineering number, similar to the following examples:
D3AE-C1A, or -C2A / D5ME-AA / D6OE-AA / D7AE-AA / There are more, (also ID numbers for the one/two/three sheaves), but whatever it is marked, will be similar.
Hi, I cant make out the whole # looks to be a D00E-? There is also a 6312,B3 and I think an 8E further around....It is a 2 belt pulley, no air...What is a sheave, the belt groove?
While on the subject of pulleys I've been trying to find a smaller water pump pulley for my 77/400ci with air and power. The existing one is about 6" and has a fair amount of set back. I can't see any numbers as it
's on the vehicle.
's on the vehicle.
