First Possible Problem, Need Diagnostic Help!
Old Jun 12, 2011 | 10:38 AM
MobeyDick's Avatar
MobeyDick
Patient is my 06, 6.0 it has 136,000 miles. I replaced the water pump about 3 weeks ago, it was leaking out the bottom weep hole. The EGR valve was replaced at 47,000. This week it started losing coolant but it doesn’t leak out to the ground, no “Puking” No drips no runs no errors. Apparently it’s coming out the Exhaust a little white smoke at times. It loses about 1 gallon every 100 miles.
I bought the truck new, I put a programmer on it for about 3 weeks about 3 or4 years ago for a Fuel mileage experiment, took it off because it didn't increase fuel mileage. The truck has never really given me any real problems.
Old Jun 12, 2011 | 10:50 AM
npccpartsman's Avatar
npccpartsman
Sounds like an EGR cooler to me. Park the truck nose down hill and pull the egr valve to see if you have some coolant puddling in the intake manifold.
You need to check your ECT/EOT delta to make sure that your oil cooler isn't plugged. That's typically the reason for EGR cooler failure.
Old Jun 12, 2011 | 12:15 PM
BLADE35's Avatar
BLADE35
sounds like egr cooler blew oil cooler is probably clogged
when you do get it fixed the truck needs a coolant filter and a set of gauges to watch your ect vs eot spread
with all the info on here you can probably more times than not see the failure coming with a gauge
dont drive it if it gets worse you could hydrolock the moter
did the truck get hot the first time you caught the coolant low
Old Jun 12, 2011 | 03:04 PM
MobeyDick's Avatar
MobeyDick
We changed the water pump about 3 weeks ago and have been watching it closely.
Old Jun 12, 2011 | 03:12 PM
BLADE35's Avatar
BLADE35
cool some people dont notice untill its to late
what gauges do you have
Old Jun 12, 2011 | 06:00 PM
MobeyDick's Avatar
MobeyDick
None other then stock, being it's a totally truck!
Old Jun 12, 2011 | 06:32 PM
BLADE35's Avatar
BLADE35
I use this
www.scangauge.com
for the price its a great unit and has saved me and alot of other folks on here
it will do eot,ect,ficm,ipr,icp,volt,boost,map and a bunch more
I was able to see my oil cooler and it was starting to plug I was able to change it before it poped and make a big mess
the newer trucks usually blow the egr cooler like yours before the oil cooler pops
you need to change both the egr cooler and the oil cooler
you can also upgrade the egr cooler to a BPD one which is what most people do that have the square cooler such as yourself
check it out here
BulletProof EGR Coolers
Old Jun 12, 2011 | 09:20 PM
MobeyDick's Avatar
MobeyDick
No Coolant/Moisture in the intake.
Old Jun 13, 2011 | 05:17 AM
npccpartsman
Have you sniffed the exhaust to see if it smells sweet or like diesel? With that much coolant loss it should be readily apparent. Moisture in the intake or not it still presents as an EGR cooler. It's possible you're just keeping it burned off too, especially if you're using your truck a lot, and you didn't say anything about leaks on the ground. Do you have a way to check difference in ECT and EOT?
Old Jun 13, 2011 | 06:18 AM
MobeyDick's Avatar
MobeyDick
I don't have the truck at hand. One of my workers is driving it. It's being Driven a lot less lately, 3 miles one way then back to his house in the evening. The Job site is a lot closer to his house then my shop so he is driving it from his house instead of the 25 miles one way from my shop. It saves about $75.00 a week in fuel for me and most likely about the same for him.
He said there is no water leaking and it's smoking white some.
I going to go swap it out with my 05 this afternoon.
Old Jun 13, 2011 | 08:53 AM
tex25025's Avatar
tex25025
Like everyone else, I'm willing to bet that it's an EGR cooler from the sound of it.
I find it funny that you think that this is your first possible problem, when you have had posts on other "problems" as well. Yes I do have a long memory for this type of thing. Although I'm sure on your end all your going to see is something along the lines of post blocked due to user on ignore list.
Old Jul 29, 2011 | 03:56 PM
MobeyDick's Avatar
MobeyDick
Ok, Put Sinister EGR Delete on. It doesn't leak and I think seat of the pants it may be slightly quicker on the bottem end! One problem though, The AC doesn't work now! Any Ideas!
Old Jul 29, 2011 | 04:06 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
The mech prob forgot to attach a vacuum hose.....is the air coming out of the defrost vent instead of dash vents? If so, that's most likely the problem.
If the truck has 4 wheel drive, (shift on the fly) that prob doesn't work either.....
Old Jul 29, 2011 | 05:15 PM
MobeyDick's Avatar
MobeyDick
No, it's coming out of the dash vents. It is 4X4, The AC clutch is not coming on.
Old Jul 29, 2011 | 05:18 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Check to see if the electrical plug (s) are attached to compressor.
