I have a 99 SD with the V-10 and the engine has 90000 miles. I have been thinking of changing engines sometime in the future and have been wondering if I can replace the 2 valve with a rebuilt 3 valve long block. Would that be a fairly ease exchange or should I just forget it....! The ole 2 valve is doing great but I pull a 38' fifth wheel at about 18000 total weight (both truck and trailer). Thanks.
The difference between the 2v and 3v isnt all that significant. Obviously you will be better suited towing with the 3v. However, the 3v only gives you 30 more horses and 67 more ft/lbs of torque. Im guessing a rebuilt 3v is going to cost in the neighborhood of $2-3000. I would reinvest that money into upgrades to your current motor. $3000 in upgrades will give you more than 30HP and 67ft/lbs.
3V's are also drive by wire, it is far from an easy swap. Also not sure about them bolting up to a 4R100. Being a '99 I'd look into a PI 2V, assuming yours is a NPI.
Spend that money on a set of gears, or sell the truck and get a newer 3V.
I'm not to concerned about more power, just reliability. The 2v has the 3 or 4 thread spark plug hole and mine have been changed 2 times and that's pushing those alum threads, I was thinking that the 3v with the thicker threads would keep me from redoing a plug hole out in Tim-buck-two. Selling/trading a V-10 around here is almost as hard as selling/trading a 6.0 diesel....the car lots are full of them.I guess I'll just wait and see what happens, I can always go with a 2v long block. I'm almost 70 so I'm not going to be pulling a 5th wheel much longer anyway. Thanks for answering.
I wouldn't worry about the plug blow out unless you have a jockey for a mechanic.... As long as they are torqued down correctly they will last for a while... plus how many miles do you have on the truck and why so many plug changes?
I have 90,000 on the truck now. I changed the plugs at 70,000 and all was well for awhile, and a miss developed. It kept codeing "verious cyls misfiring" so I changed them again. Turns out is was a bad fuel pump. I picked up some bad gas that stopped up the frame filter and it ran ok after that change but then came back, unbeknost to us the in tank filter was clogged too. So we changed the pump and all and haven't had any issues since.
have you changed the COPs? I know the coils on these motors seem to die a lot.... I've replaced 5 on my 99 and 3 on my 06.... just givin ya some pointers if the miss develops again
If you have been installing and torquing the plugs correctly, the threads will last forever.
The 2V to 3V conversion is rather difficult because of the electronics. The only PCM's available for 3V also need to see the 5R110 tranny AND the buss electronics.
The other approach is to convert a 3V long block to use 2V electronics and throttle body. That will require fabrication (particularly getting a cam timing sensor to work correctly).
On the other hand, I found the the PI head and intake conversion to be well worth the effort.
There is more of a difference than you think. Not just in hp and tq numbers but in the physical parts of the engine, control system and some bolt on components. An NPI 2V 6.8l makes 275hp and 410 tq where as the 3V 6.8l makes 362hp and 457tq, so thats an 87hp and 47tq difference.
The 3V short block is useable with the 2V components but thats about it. I have never seen anyone successfully swap a 3V V10/5R110 combo into a 99-04' SD. Honestly you would be better off just buying a used 05' up truck with a 3V unless you have a lot of extra time and money. Or just swap in a later 2V PI long block.
Where are you getting your numbers? I have not seen these numbers. 2V 6.8 is 310/425 and 3V is 362/457 with is approx 50 hp/30 tq.
