Pennsylvania Chapter Join Chapter, Leader: liftnw8z
RUST!!! part two.....
Old Jun 11, 2011 | 01:26 PM
Microchudd's Avatar
Microchudd
Greetings !!!
Found some rust on my cab corners the other day.....rust that i could put my finger though.. the driver's side has a hole about as big and as long as a guy's thumb on it, and the passenger side has a small hole... should I just suck it up and take it to a welding place? or try a home repair?? It's on the bottom, so there are no holes into the cab itself...
Old Jun 16, 2011 | 03:24 PM
grumpy hvacr's Avatar
grumpy hvacr
Whatever rust you first spot will get much bigger once you start playing with it.
The real question is do you really want to learn how to do bodywork.
A bunch of work, money, and you could have your truck tied up for a while.
You might find out you like it-you might not.
You will end up with a bunch of cool tools.
Rocco
Old Jun 16, 2011 | 04:40 PM
dustybumpers's Avatar
dustybumpers
Cab corners are cheap. To put them in, you need to remove the bed, then cut out the bad metal. You need to weld them back in, to do it properly, but some use pop rivits. Some painting will be required. I have a couple of sets of cab corners for 80_ 86,you can use them on 87_96,the only differance is a small tab on the bottom, and the bed hides that. I can bring them to the show in Auther in Aug if you want a set.
Old Aug 28, 2011 | 10:17 AM
650's Avatar
650
Let a pro do it for a couple hundred bucks unless you dont care too much about what it looks like.
Old Aug 28, 2011 | 06:03 PM
Microchudd's Avatar
Microchudd
yeah thats the plan if the guy and I could just meet up... lol
emeraldcoupe
Jul 11, 2014 01:35 AM
Microchudd
Jun 11, 2011 02:26 PM
Becca_78
17
Jul 21, 2010 03:00 AM
tenforty_2
Aug 2, 2008 10:31 PM
john g
Paint & Bodywork
Dec 14, 2000 06:25 PM
