oil pan
Old Mar 26, 2003 | 08:56 AM
Rich1952's Avatar
Rich1952
oil pan
I sure need a little advice on how to remove the oil pan on my 1965. I recently purchased this truck and it has a <a href="http://motorhaven.autoanything.com/">352 </a>and over the years the pan drain hole threads have been stripped. Do the self tapping plugs I've heard about work. Gasket is also leaking a little.....the pan should be removed and the job done right, but I have never done this job on a Ford. Can someone please tell me what I am up against. Also I just can't seem to get the search function on the board to work, what am I doing wrong.
Thanks for any advice.
Rich1952
Old Mar 26, 2003 | 12:04 PM
Mike G's Avatar
Mike G
oil pan
Hey Rich:
Welcome aboard! The times that I have done this in the vehicle usually all require the same work, just a little different. Unsually, start by unbolting the motor mounts, place a set of blocks under the lower (crank) pulley and this will allow you to jack the engine up to remove the pan. Use common sence and watch for the hoses/wiring so they don't over extend and something gives. Shoule be able to pull this off. Might need/be best to put blocks under the motor at the mounts rather than depending that the jack won't be in the way when you attempt to remove the pan.
Good luck!
Old Mar 26, 2003 | 01:22 PM
Rich1952's Avatar
Rich1952
oil pan
Thanks Mike......Little bits of advice like this can save a guy a lot of grief.
Rich
Old Mar 26, 2003 | 11:32 PM
packrat_1954's Avatar
packrat_1954
oil pan
Try this first. go to your local parts house, and get a new STANDARD size drain plug. should be 1/2 inch. and see if it will screw in and be tight. On most Ford oil pans, they used a hardened metal tab inside the oil pan, and a soft drain plug, so the plug would strip, and not the pan. When people decide they need to install a oversize drain plug, they crack the hardened tab inside the pan, and then, they have to pull the pan. May try running a tap in the pan before installing the new plug...just my two cents..
Dorsai
21
Jun 9, 2020 09:21 AM
6.9 BLUES
Apr 2, 2014 12:21 AM
Gf2501
Nov 20, 2013 02:31 PM
ottawaguy
23
Mar 22, 2009 05:31 PM
bryanknie
Flathead V8 & Flathead 6
Aug 29, 2002 09:52 PM
