Gear Ratio ?
Old Jun 10, 2011 | 06:51 AM
bergy 2000's Avatar
bergy 2000
Gear Ratio ?
My x has a v10 and 4.30 rear. The P.O. put 245/75/16 E rated tires on it.
What does the ratio work out to be equivalent to with the smaller tires?
They are like new so I am not changing them at this point. I do tow a good bit as well and I think it helps with torque. Its a 2wd and ground clearance is ok too. Besides if I get 265 or bigger I will have a real hard time getting into my garage. My wife wont mind me storing her out side(so she can have all the room) but I hate to see my baby un protected.
Old Jun 10, 2011 | 07:40 AM
ExxWhy's Avatar
ExxWhy
My math might be fuzzy this early, but I'll give it a shot. Methinks this is the right way to figure it.
A quick check shows a Michelin LTX MS2 takes 683 revolutions per mile in size 245 and 657 per mile in 265. About 104%. Multiply that by 4.30 and you get 4.47.
Other brands should have a very similar difference in RPM's. Your speedo is off by 4% low and the weight rating is about 400lbs less per tire.
Old Jun 10, 2011 | 07:59 AM
bergy 2000's Avatar
bergy 2000
Makes sense. I already adjusted the scan gauge II 4% so adding 4% to the ratio would make sense. Thanks
Old Jun 10, 2011 | 08:52 AM
X_Hemi_Guy's Avatar
X_Hemi_Guy
Using Automotive Calculators offer to you by Ford Trucks Enthusiasts | www.ford-trucks.com I come up with 4:47 also.
The 265/75/16 tires are 31.65" in diameter
The 245/75/16 tires are 30.47" in diameter
If you use the automotive calculator I link to and put 31.65" as the "orginal" tire diameter and the 30.47" as the "new" tire diameter and put 4:30 as the gear ratio...it calculates 4:47
So two independent methods yields the same 4:47 ratio...
Joe.
Old Jun 10, 2011 | 06:23 PM
wpnaes's Avatar
wpnaes
Check your garage door (if electric opener) stop near the opener motor on the guide rail. They can be adjusted to open the door a bit higher (nearly even with the header). That might give you another inch. Or take off the useless stock roof rack sliders (makes your roof paint happier too). I hate to see an Ex with 245's
SoloAK
33
Aug 9, 2016 02:00 PM
Nolo263
Sep 15, 2014 09:24 AM
Packard V8
Oct 27, 2009 06:20 PM
BFR250SD
Jul 1, 2005 09:18 PM
JBL
2004 - 2008 F150
Jan 7, 2005 05:32 AM
