Newbie here. Had a used 5.4L motor installed in my 2000 Ford Excursion. A week later the oil gauge went crazy and a tanish yellow sludge started erupting from the radiator overflow. The mechanic who installed the motor said that the engine oil cooler had failed and that the oil was forced into the cooling system. So I replaced the engine oil cooler and spent an entire day trying to flush the sludge from the engine cooling system. The truck was running nice and smooth until I did the flush of the cooling system. Now it is running very rough. The engine was sprayed down to rinse off all residual from flush. Now it acts like it is missing. Driving down the road causes it to seem to bog down at certain speeds. Could the belt have slipped and the timing be off causing this issue? Any other clues or suggestions are greatly appreciated?
David
Year : 2000
Make : Ford
Model: excursion
Engine: 5.4L gas
Since you mentioned that you sprayed down the engine, I'm wondering if you have water down the spark plug hole creating a short (misfire). Are the plugs and boots new?
Plugs are new, boots are not that I am aware of. I believe that the mechanic pulled all of that from the old blown motor. Any way to "Dry" out the spark plug hole?
You'll need to pull the COP and boots off and blow them out with compressed air. While you have them off, get yourself a new set of boots. Reinstall using dielectric grease.
Hopefully your COPs are still ok and didn't get shorted.
The oil cooler fails a week after the mechanic installs the motor and you wind up with oil in the cooling system.
My initial reaction is that you've got a bad head or bad head gasket on the new motor and oil and water are mixing in places where the aughtn't be mixing.
Can you pull the plugs and inspect them? You know that oil has been forced through a gasket into the cooling system somewhere. If a plug is wet (oil or coolant) you've got a lot more serious problems with this motor than just a misfire.
A crack in the old rubber boot could allow water to seep through and make an electrical connection to the hot wire to your plug. That's why it is always a good idea to replace those boots when you change the plugs.
Well folks all plugs and new boots installed. The engine starts but runs VERY rough, even at idle. At 35-40 truck starts shaking violently. (OK maybe a little extreme) What can be done to adjust the idle?
You can try pulling each COP one at a time to see which one may be misfiring, if that is the issue. If you pull one and there is no change in how the engine idles, then that's the one.
