map sensor
Old Jun 9, 2011 | 04:09 PM
2005f-150's Avatar
2005f-150
map sensor
i just pulled the codes on my truck and i am still getting code 122 map sensor vacuum leak. i replaced the sensor and still get the code the vacuum line looks good. so now where do i look? also will this cause a cel and rough idle/staling while at idle? i had my upper intake off not long ago to replace the pcv and put a new gasket on the intake would that have any thing to do with it?
Old Jun 9, 2011 | 04:18 PM
2005f-150's Avatar
2005f-150
i should also ad i had that code before i pulled the upper intake off
Old Jun 9, 2011 | 04:28 PM
rla2005's Avatar
rla2005
DTC 122: KOEO TPS circuit below minimum 0.6 volts. CM TPS circuit has intermittently failed below minimum 0.6 volts.
You are barking up the wrong tree. It's a TPS problem not a MAP sensor.
Old Jun 9, 2011 | 04:29 PM
danr1's Avatar
danr1
Talking about your 93? code 122 is TPS circuit below minimum 0.6 volts, nothing to do with "Map".
Where'd you get that result?
Old Jun 9, 2011 | 04:36 PM
2005f-150's Avatar
2005f-150
i was thinking 122 was map sensor but i was wrong, now with the correct question i replaced the tps and still get the code. i installed it correct with setting it on and rotating till the screw holes line up and tighten them.
Old Jun 9, 2011 | 04:51 PM
danr1's Avatar
danr1
Did you check for proper reference voltage from the PCM? Should be approximately 5v. If for some reason its really low or non existent due to a pinched/cut wire or a corroded connection you wouldn't get the required min sig return voltage and it throw that code with a good TPS.
Old Jun 9, 2011 | 05:10 PM
2005f-150's Avatar
2005f-150
no i didnt referance the voltage but i will as soon as this rain stops
Old Jun 9, 2011 | 06:02 PM
2005f-150's Avatar
2005f-150
i just checked it, on the black wire i have 1.4ohms, orange wire has 5.05v and green wire has .09-4.21v with a steady increase to wot and decrease to closed position. so that means i got a faulty tps right?
Old Jun 9, 2011 | 06:23 PM
danr1's Avatar
danr1
Your wire colors are different however,
Resistance "ground" to "signal wire" should be 3.0 to 4.0k, throttle fully closed (harness connector removed naturally).
Slowly open throttle rise to full open = 350ohms, should note smooth change throughout range.
Old Jun 9, 2011 | 06:33 PM
2005f-150's Avatar
2005f-150
so basically my tps is good right? what else would cause this code
Old Jun 9, 2011 | 07:38 PM
ChristopherN's Avatar
ChristopherN
Did you remember to screw on the ground wire to the upper intake?
Old Jun 9, 2011 | 07:49 PM
2005f-150's Avatar
2005f-150
i dont remember i am pretty shure i put every thing back to its original location except the pcv vacuum line. where should i look for it? i had this code before i pulled it off tho. my truck has been doing the same thing since i got it not running/idleing right. i am at wits end with it. at least i got it down to one unexplained code that i cant figure out.
Old Jun 9, 2011 | 07:51 PM
ChristopherN
Left side of the Intake manifold lower mid way about. There's also a ground wire on the hood left hinge. Those are the ones I can think of that could have possible been dis connected.
Old Jun 9, 2011 | 11:57 PM
timbersteel's Avatar
timbersteel
I would do a resistance check from the PCM harness to the TPS connector. Also, was the battery disconnected for a period longer than 5 minutes when doing the repair work?
I would check Reference voltage cold and then after the engine has reached operating temperature. Also, has the Throttle position Screw been adjusted from Factory setting?
Old Jun 10, 2011 | 07:32 AM
vochy's Avatar
vochy
Does anybody have a pic of this ground wire?
